GAS CAP!!
GAS CAP!!
Postby drj » Fri Jul 07, 2006 8:54 pm
is it just me - or does everyone occasionally have to fish out the parts of the gas cap (rubber seal - metal insert) from the neck of the tank...
ive been lucky so far - but one of these days that damn thing is gonna go ALL the way in - and then ill be up the creek - with no bike.
am i missing something - or am i just a bonehead?
drj
'03 Baghira (m4 pipe/black rims)
'01 XR650r (hotcam)
'00 XR400r (pumper/header/pipe/cam)
drj
Postby sandberg » Sun Jul 09, 2006 2:40 pm
I had the internals to my gas cap fall apart but was lucky enough to get a replacement while they wer still in business.
sandberg
Postby beamisinbtw » Sun Jul 09, 2006 7:08 pm
Mine tends to fall out after i remove it from the tank. It seems as if the rubber is a bit small for the cap. I may get keyed cap from bsa.
beamisinbtw
Locking gas cap
Postby handsomejackuk » Mon Jul 10, 2006 9:57 am
Hi just to throw something else in I got a locking gas cap on mine. It was on when i bought the bike also i got adjustable suspension tops blue twisty nuts and i got rubbers on my footpags these must all be dealers extras, as i not seen these on other baghiras
Alun
handsomejackuk
GOOD NEWS!!!!
Postby drj » Mon Jul 10, 2006 9:30 pm
yesterday while i was out and stopped for gas - IT FINALLY FELL ALL THE WAY IN - SHEEIITT!!!!!!
now what the hell am i gonna do????
someone please tell me i dont have to get a whole new gas tank!!!PLEASE!!
crap.
shit.
damn.
drj
:evil:
'01 XR650r (hotcam)
drj
Postby drj » Tue Jul 11, 2006 10:41 pm
bueller.
bueller.
bueller.
anyone.
anyone.
anyone.
'01 XR650r (hotcam)
drj
bueller
Postby DAVID THOMPSON » Wed Jul 12, 2006 11:06 am
yes we understand next time you have a day off
take the tank off and drain the gas turn tank upside down and using a dental Mirror and wire with a small hook go fishing for it
tank needs cleaned out any way if bike is more than a couple years old
ps i drive a school bus so i speak high school english
bueller == Ferris Bueller's Day Off = every thing i did today was screwed up :-D
Postby drj » Thu Jul 13, 2006 8:01 pm
the only problem with that suggestion is that the metal cap is the EXACT SAME SIZE as the opening itself...
my plan is to get a hold of it with some pliers - crush it - then extract it...and i probably wont be replacing it.
i dont think i needed it to begin with...(a very silly part indeed)
i mean really - a metal cap that ISNT attached to anything that also happens to be just small enough to drop inside the tank...NOT TOO SMART! :evil:
drj
:-D
'01 XR650r (hotcam)
drj
Postby keithcross » Fri Jul 14, 2006 7:02 am
Do I understand you right, you have a metal part in the fuel cap? Mine Baghira doesent have this, and as I brought the bike brand new I dont think it was ever fitted. The rubber part does come out of the cap sometimes, but to date I havent had a real problem with it.
Handsome jack, the blue adjusters on the fork tops are standard on the top of the front forks on the normal height Baghira. They are not fited to the reduced height Baghira and the Mastiff. I am sure the rubber footrests are not standard on the normal height Baghira though. I reckon Yamaha parts could be fitted though.
Postby drj » Fri Jul 14, 2006 3:07 pm
keithcross wrote:Do I understand you right, you have a metal part in the fuel cap? Mine Baghira doesent have this, and as I brought the bike brand new I dont think it was ever fitted. The rubber part does come out of the cap sometimes, but to date I havent had a real problem with it.Keith
did you purchase your bike new - or used?
it may already be inside your tank too!! :smt119
drj
:smt017
'01 XR650r (hotcam)
drj
Postby dbird » Fri Jul 14, 2006 4:01 pm
i had the same problem with the metal cap...one time it got stuck and i couldnt figure out how to get it out. it came out eventually but then after a couple more tanks i noticed it and the rubber peice were both gone. i hope mine arent inside the tank as well???
dbird
metal part
Postby DAVID THOMPSON » Fri Jul 14, 2006 6:12 pm
the metal part may be a one way air valve...
it lets air into the tank and air is let out of the system
via the charcoal canaster fitted to usa sold bikes as needed
ie as a cold gastank heats up setting in the sun in the morning
but may not be on a bike in other areas ie keith had none on his in the uk ????
Postby drj » Sat Jul 15, 2006 12:23 am
either way - the dang thing was a bad idea from the get go...
my dirt bike also has an acerbis tank - but that doesnt have a metal cap - and they both have a breather hose...lame.
c'est la vie!!
drj
'01 XR650r (hotcam)
drj
Postby cat » Sun Jul 16, 2006 3:27 pm
David's right, and Keith's right. It must be some EPA / USA stuff. Mine is just a standard-type Acerbis plastic cap with a rubber gasket.
cat
Postby drj » Tue Jul 18, 2006 12:48 am
either way - its gone now...and it WILL NOT be replaced...
so the question is - what happens to an aluminum cap that sits in a gasoline bath for a while???
will it foul up my fuel lines...?
will it decay and gumm up my carbuerator...?
or is it not THAT big of a deal...?
i dunno. runs fine for now.
drj
:roll:
'01 XR650r (hotcam)
drj
