running rough
running rough
Postby Roadrunner001 » Tue Jun 06, 2006 8:52 am
my 660 Skorpion seems to of started vibrating more than it used too :-(
seems to idle fine, it's only once I'm moving that it becomes evident, could the chain & sprockets be needing replaced? I'm not very mechanically minded but the place I used to take the bike for maintenance has closed down, now I'd have to travel about 50 miles so need to try and do more myself
Puch Maxi, Hyosung Cruise 2, MZ Traveller
Roadrunner001
Vibes- things to check .
Postby jimc » Tue Jun 06, 2006 10:23 am
Does it do it coasting with motor off? Any particular speed (tire balance)?
Put the bike up on the center stand manually spin the rear wheel and check out how the chain appears to run, look for tight/loose and the condition of the teeth, check rear wheel axle alignment marks.
Spin the tires & look at that too.
Also, does the front & rear suspension seem to move OK or is there any binding?
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Postby DEmark » Tue Jun 06, 2006 11:00 am
Check the motor mounts. Are the bolts tight? Are there cracks in the brackets?
DEmark
Postby Roadrunner001 » Fri Jun 09, 2006 7:49 am
it only happens when the engine is under load, I've checked the chain and it appears to be a little loose but not too bad, I'm gonna adjust it at the weekend and see if that cures the problem
Roadrunner001
vibs
Postby DAVID THOMPSON » Fri Jun 09, 2006 8:33 am
check the front sprocket NUT and locking tab
both my saxon tour and rt125 have came loose in the last 2 years
Users browsing this forum: Bing [Bot] and 14 guests
