Interchangeable parts - a list
Postby F0ul_Oli » Fri Mar 18, 2005 7:13 am
I was thinking how nice it would be to have a list of stuff, designed for other bikes, that fit the MZ range ( In interested in the Baghira, but lets make the list for everyone)
So far, I know the engine is a Yamaha 660cc and all the normal service parts fit.
The front disc is a Yamaha R1/6 model -99 - are the calipers also from this bike?
The front mudguard is a KTM model, but I don't know which bike!
The Rear brake Cylinder is also a KTM but which model?
What about the clocks? Did someone say they were from a Husky?
It seems to me the only bit which you can only get from MZ is the frame!
If we all put down our words of wisdom, we could edit the whole thread at the end and create a document for easy reading - what do you think?
F0ul_Oli
Postby keithcross » Fri Mar 18, 2005 10:42 am
The later style (not the square ones or the round ones) are the same as a Huskvarna (spelling not quite right but you get the meaning) SM and the husky tacho can be made to fit as well (electronic).
The front brake caliper is NOT the same as a Yamaha R6. The Yamaha unit is a four pot calpier, the MZ a 2 pot sliding caliper.
The KTM front mudgaurd like many others will fit (I have a Suzuki RM, UFO pattern one fitted to my Baghira)
Brilliant idea about this documant as well.
Dougal
Postby F0ul_Oli » Fri Apr 22, 2005 5:19 am
Just added some bits about the brake pads here.
Engine -
Service parts are the same as Yamaha XTZ 660
Oli Filter - Yamaha part # 4X7-13440-90
radiator guards for a KTM LC4 640 fit the Baghira perfectly
Electrics -
Tacho - The later style (not the square ones or the round ones) are the same as a Huskvarna SM and the husky tacho can be made to fit as well (electronic).
The CDI units from the following will fit.
Yamaha SZR660
Yamaha XTZ660
Any MZ 660
yamaha TDM 850 3VD item, not for the 4TX series. - The rev limiter is set at 8400rpm, ignition some degrees earlier (38° to 42°.
Battery off an XT600 will fit.
replace the original headlight bulb with a piaa super plasma bulb
Exhaust -
You can use a connector pipe from any 660 based bike, the back box needs to fit the end of this connector pipe ( my back box was once on a Fireblade! - this is because my connector pipe will accept any end can with a 50mm inlet - standard size for the Ducati 749 underseat pipes!
Brakes -
The Aprillia Pegasso uses the same FRONT pads as the Baghira and the same REAR pads as does the Yamaha TDR 125
Plastics -
The headlamp is a stock KTM fittment
The front mud guard is a pattern part, as is the rear number plate holder
Larger Fuel Tank -
None available but a KTM model can be modified, but the seat also needs replacing.
Wheels -
Rear Yamaha 41 tooth sprocket JTR857-41
F0ul_Oli
Postby bikerbabe » Fri Apr 29, 2005 1:43 pm
Brill idea peeps :lol: If I find any interchangeable parts I'll post 'em here.
Can't think of one.
bikerbabe
Postby gedge » Sat May 07, 2005 5:09 am
The standard baggy headlamp is also a KTM item.
radiator guards ( if you want them )are off a KTM LC4 and so the rads are also from the same model..
gedge
Postby tuny » Wed Apr 12, 2006 1:37 pm
the wheels from the mastiff, where do they come from? not the spocket one"s, i mean the aloy wheels.?
tuny
Postby keithcross » Wed Apr 12, 2006 1:57 pm
The standard Baggi headlight unit is also the same as those fitted to Huskvarnas and Husabergs amongst others
The rear shock protector/mudflap is the same as a KTM 640.
Front and rear sprockets are teh same as teh Yamaha XTZ660.
Alloy wheels are a MZ item. They require a different sized spindle for each wheel though. They are very similar to CCM R30 wheels as well.
Wheel hubs are modified Yamaha units (different bearing sizes)
All engine componants are teh same as Yamaha XTZ/SZR 660.
As are starter motor and carbs.
Postby tuny » Mon May 22, 2006 1:24 pm
are all cluchtes of baggi, mastiff and scorpions the same? so can i order a cluch of a scorpion to fit my mastiff?
tuny
Postby keithcross » Mon May 22, 2006 2:20 pm
All 660 enigines from the MZ 660 and Yamaha XTZ and SZR 660 are the same.
Postby tuny » Mon May 22, 2006 11:28 pm
keithcross wrote:All 660 enigines from the MZ 660 and Yamaha XTZ and SZR 660 are the same.
i know this is not right, becaus the szr hase a different gearbox it's 1e is much longer then the baggi's 1e. but maybe the cluch is the same, i'l try it. why do they ask the date of make from a scorpion fore the cluch on ebay???? (is there a diference?)
tuny
Postby keithcross » Tue May 23, 2006 2:38 pm
Just looked up the reference number for friction plates and springs for the SRZ660 and the XTZ660. Same part number. Interestingly the new XT660X and R have the same friction plates as well.
Seat Bolts!!
Postby TrashBagh » Thu May 25, 2006 12:51 pm
Hey people I've got an 03 Bagh which is missing two out of the three seat hold-down bolts... anybody have any leads as to where I can locate replacements?
TrashBagh
Postby RiverDrive » Thu May 25, 2006 3:04 pm
01 Sport Cup Gone Sport
RiverDrive
Postby cat » Fri May 26, 2006 3:26 am
keithcross wrote:Just looked up the reference number for friction plates and springs for the SRZ660 and the XTZ660. Same part number. Interestingly the new XT660X and R have the same friction plates as well.
Can you give me the part number for the list? What about the springs?
cat
Postby keithcross » Fri May 26, 2006 12:00 pm
The catalogue I have is from M & P motorcycle accessories in the UK. See
http://www.mandp.com
The part number thay give is 508 563 (£46.50)for the friction plates and 508 694 for the springs (£7.50). Prices plus P&P. No makers name is included in teh catalogue.
Users browsing this forum: No registered users and 245 guests
