slipping clutch
slipping clutch
Postby tuny » Wed May 17, 2006 11:28 pm
some times wheb heavy abused my cluch slips, is this normal or does it needs to bee changed? what costs a set of plates and maybe stronger springs, anyone got stiffer springs in ther cluch?
tuny
Postby phlat65 » Thu May 18, 2006 9:26 am
make sure the freeplay in the cable is ok after the clutch is heated up, a missadjusted cable can cause the clutch to slip. stiffer springs might help, but probably too much disk wear already....
Postby dmon722000 » Sun May 21, 2006 7:47 am
New clutch pack time!, Dont forget to get the gasket required to replace the original one that will be wasted during the operation. Might as well get a oil filter also and some Motorex race oil too.
Galen@Bikeworx(.com) USA should have what you need.
good luck
P.S. you can replace 1/2 of your stock springs with the race versions, the full race is hard on the hands if you get stuck in traffic
dmon722000
Postby tuny » Sun May 21, 2006 12:48 pm
ok wil do can i change it while engine still mounted? what would a cluch cost, i 'm from belgium so its euro"s
tuny
Postby keithcross » Sun May 21, 2006 2:19 pm
The clutch can be changed with the engine in the frame. I have removed this cover on my bike in the past.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
