So here now my nearly finished MZ now is so far finished it. Thus all changes: powder-coats rims(matt black) tire (Avon Azzaro 120/70 17 ; 160/60 17) Fork tread (small) carbon fender -ZAP aluminum steering wheel Steering wheel increase (30 mm) Folding mirror with e-test characters Antlers remove new H4 pear, red Tacho and Parking light pear Turn signal in front/in the back (lining turn signals of Kellermann) Brembo PSC pumps Stahlflexbremsleitung in front Brake linings (AP racing) for Sozi. plant removes High-grade steel chain protection For -LED taillight + self-build mounting plate number sign plate original exhaust Tank backpack
Which is still missing: - lacquer finish (correctly coll red effect) - ESD (with ABE is however heavily) nen - lamp masks change (build at fork) - rims which I drive can (to come now finally on Monday completely finished) - hand treads (paints again even from carbon optics in matt black), are however meanwhile installed only net on the pictures.
with antlers, the owner for the speedometer (the handle) is meant. The mirrors are not KTM or Yamaha of parts them are from the accessories them with my dealer bought.
Dont forget about the front forks, Paint them up (hopefully black). Might as well since you have the front end apart, maybe change the front fork oil and paint the upper triple tree bearing dust cover, they rust up quick...
