my mastiff 680
Re: my mastiff 680
Postby cat » Tue Apr 11, 2006 1:52 am
tuny,
It looks like you've got a green exhaust/muffler slider/protector ...? (I was reading about how to make these on supermotojunkies the other day.)
And your sliders, the ones you've got mounted by the radiators -- please tell more.
cat
Postby CM » Tue Apr 11, 2006 3:25 am
I guess that the slider at the exhaust is a piece of a tube.....
CM
Postby cat » Tue Apr 11, 2006 4:49 am
CM wrote:I guess that the slider at the exhaust is a piece of a tube.....
Yes. They make them from car coolant tubes, something like that. Get tubing + big hose clamp, measure, cut, and slowly work the hose clamp through it, flattening the tube with a vice and heating it to work the hose clamp through it.
The coloured ones are made by a guy in the UK, on e-bay; 2 of the guys on the smj thread had got from him. (And then seen they could make better themselves.) It is for racing, when you want to save the exhaust from slide damage.
I saved all the pictures from smj.
cat
Postby cat » Tue Apr 11, 2006 4:59 am
the other 3 photos:
cat
Postby tuny » Tue Apr 11, 2006 1:52 pm
yes its a tube wich i painted on the inside same color green as the bike. the one's on the radiator are home made, i made new plates to mount hte engine, the new ones are 6mm thick drill a hole, put barr in and weld it together on the in and outside of the plate, make, blocks fit and mount everything, i'v got 1 mastiff more to mount these on, when i do so i will make some pics.
this week i dropt the mastiff on road and need to say the blocks are perfect length nothing scratcht just handelbar and the blocks.
tuny
Postby cat » Tue Apr 11, 2006 2:12 pm
tuny wrote:the one's on the radiator are home made, i made new plates to mount hte engine, the new ones are 6mm thick drill a hole, put barr in and weld it together on the in and outside of the plate, make, blocks fit and mount everything, i'v got 1 mastiff more to mount these on, when i do so i will make some pics.
Ja, asseblief, fotos. dis 'n goeie idee. :-D
cat
Previous
Users browsing this forum: Bing [Bot] and 12 guests
