andyw wrote:'Twin Air' filters for the MZ Mastiff,the part no you require is 154512
.......or as I did by luck find the same filter as listed for the KTM SC/Duke and Maico 98/03.
No-Toil air filter maintenance kit - aerosol bidegradable filter oil, filter grease and cleaning fluid (try MX shops)
Hoke wrote:Headlight is the same as for the Husqvarna/Husaberg to (cheaper here in Sweden) and a lot of other KTM and offroadbikes, the TTR 600 fits to (but is not H4).
The indicators are the same as some Husqvarna/Husaberg to, some mopeds have them to (then they get really cheap).
Hoke wrote:Airfilter: KTM Duke 1 (DT1 RW 250-02) will fit ok.
Hoke wrote:I think that the rear breakdisk is the same as the "old" BMW 650 Funduro and the front one as the older Yamaha R6.
Hoke wrote:And of course the engine and the carb is the same as Yamaha XTZ660, so all XTZ-engineparts will fit...
Hoke wrote:Stock rear sprocket on the MZ 660 Baghira Forest (1999) = 45 tooth.
keithcross wrote:The R1 front disc I have on my Baggi is the early type, up to 2002 I think. Its also the same as the Yamaha Thunder Ace.
Indicators are also the same as fitted to some Triumphs and Ducatis. Front brake light switch same as some Aprillia's,
Most smaller o rings same as XT600,
Sprokets are the same as some model years of the XT600/TT600. I think you will find this on the site somewhere.
Hoke wrote:The front brake light switch are the same as the KTM LC4:a, and one off the two most common universals -just take the old one with you to the dealer and compare.
Hoke wrote:Does anyone know what ignitionlock the Baghira have?
I can not read what is printed on mine after someone tried to take my bike.
On top it is printed ZADI (brand) and something like Q933?? I can only for shure read that one 9 is printed.
On the bottom it says ZADI PF385.
If it is Q933 it should be the same äs CCM 404.
The 933 (Aprillia Pegaso)/ KTM LC4 00- looks the same but have no "parkinglight" mode.
Does anyone now what the number is on the top of the lock?
Edit: In the usermanual it stand that it is Zadi Q933
Users browsing this forum: Google [Bot] and 13 guests
