Anyone help me out and give me a blow by blow description of the routine for the Mastiff please?
What AntiFreeze/Coolant is recommended or do you use?
Andy
phlat65 wrote:there are many coolant formulas thee days, just stay away from the high silicate formulas. something interesting I just read, conventional coolants use silicate to lay down a corrosion protection layer, that depletes pretty quickly from the coolant, but the new mixes like dex-cool and such suspend the corrosion addatives in the coolant so they last a long time. that is why they consider them lifetime.
having worked on VW's for a lomg time, the blue coolant is the only formula that will keep a water cooled vanagon from corroding the heads at the gasket area and leaking. and it works well with aluminum engine parts.
keithcross wrote:The problems with High silicate coolant is well known in another club I belong to. Silicate is basically a fine sand, this scours the inside of the water jacket. Unfortunatly it can also wear the water seal in the water pump.
Users browsing this forum: Bing [Bot] and 13 guests
