http://www.mzriders.com/album_pic.php?pic_id=193
The Trailtech unit will be removed shortly.
And this is the LED rear light I have fitted. No picture of it on the bike though.
http://www.mzriders.com/album_thumbnail.php?pic_id=196
[b]cat wrote:oh boy, that's good!![]()
It's even got all the lights. Yep
Where'd you get it? How much? Is it lighter, d'you think? - At least you lost the heavy speedo cable. It lighter then the original instrument pod
And the magnet? I was looking at the magnets on a site where I was ordering other stuff, but they didn't have one that was 7mm diameter and I know they're hard to grind. I've been meaning to look at the trailtech magnets. But you've got an R1 disk.
I Glued a trial tech magnet to the disc itself for the tailtech unit over 18 mnths ago with araldite (not the rapid stuff thought) and the same magent works with the one supplied with the ace unit
One thing I've wondered about though is what happens when the battery is finished - do you lose the total mileage?
It powered by the bikes battery so no internal batteries to worry about. The odometer reading is retained when the unit is disconnected.
And I see you've got lights. I've thought of getting something small to add to the headlight. (The nickname cat is from years ago when I had good night vision.)So that's one good thing about the "bullbar" - you don't have to organise light mounts.
keithcross wrote:I am suprised you dont see more of these units as well. Its a lot of extra £££ to have th eidiot lights, but it does make the whole set up tidier.
Lots of motard riders cant fit them though, no battery to run it
