credit wrote:does any one know which springs I need to stiffen my suspension on my reduced height baghira and is race tech and eibach the best place to get them
credit wrote:cat I will go with eibach springs in the front. the shop doing the install ordered them. in the rear what should I do. Hyperpro say thhey don't have a direct replacement
keithcross wrote:I will check the parts cat tonight, but I am sure the Mastiff and height reduced Baghira share the same rear shock. The normal hieght Baghira definatly has a longer rear shock than the height reduced version.
keithcross wrote:Centre to centre of mounting bolts
Baghira, Bahira Street moto - 425mm
Bahira HR, Bahira SM HR, Mastiff - 412mm
Spring length in untightend position.
Non HR models 260mm HR models and Mastiff - 240mm
Spring rate 75Nm and 85Nm respectively
keithcross wrote:I've got the parts book in front of me and it says:
I have various other recommended settings if you want them.
Users browsing this forum: Bing [Bot] and 359 guests
