TEIKEI carburetor jets available at off-the-road.de
http://www.mzriders.com/viewtopic.php?p=7484#7484
carb modifications. The mixture screw gets backed out (Holeshot Performance recommends 7 1/2 turns out from lightly seated), the main jet isn't adjustable, you replace the 130 main jet from the left side (as you're sitting on the bike) carb with a Kehin 135 and screw it in all the way tight. The midrange jet needles (both sides) get raised 1 notch, (this means the circlip goes in the second groove from the pointy end), cut 2 coils from the constant velocity slide spring (right side)and re-install cut side down. Be sure to line up the diaphragm correctly, there is a little tab on the edge of it that fits into a recess cast into the top of the carb. At low altitude (below 5000 feet), you can drill the right carb's main jet with a #51 drill bit, just twist it between your fingers, no need for the drill press and re-install with a new P/N 90-20.142 crush washer. For around town riding this last step isn't really nessesary, you'll foul plugs more often and you should definitely keep a stock main jet (P/N 90-20.146) handy if you plan on doing any riding up in the mountains. The sync screw on top of the carb bank controls the point after the low speed carb carb starts opening that the high speed carb begins to open, crank it in a turn or two so that as you twist the grip, you'll feel the freeplay take up, then the low speed carb start to open, then the added resistance of the high speed carb opening. You want the high speed carb to open just after the low speed opens, without as much of a delay as with the stock setting. This obviously needs to be set with the carbs reinstalled on the bike before the gas tank is replaced. Lastly, if your bike is a Skorpion (Sport, Traveller, Replica, etc., not a Mastiff, Black Panther, etc.), remove the black rubber snorkel from the top of the airbox.
You can also drill out the air damper hole on the CV side (the hole next to the needle) to 4mm; this allows the air to move faster so the slide comes up quicker. and I also recall installing a larger pilot jet, but there again I was running a race exhaust.
roge-a-billy wrote:No mate there 88 pounds as well I've checked, they have not updated there web site
Users browsing this forum: No registered users and 387 guests
