Main Fuse - Skorpion Sport?
Postby AndyDent » Tue Jan 17, 2006 6:51 pm
G'day Guys
My main fuse blew yesterday. It's a barrel type 20A fuse that sits alone in a black cylinder with a screw-in end.
I can't see it on the wiring diagram, which lists the three fuses that sit in the "fuse bux" but not this one.
Does this mean it is an aftermarket mod? It looks original (tacky).
thanks
Andy
AndyDent
fuze
Postby DAVID THOMPSON » Tue Jan 17, 2006 11:23 pm
my wire drawing for tour shows a 15 a from batt plus into main harness
and a 3a feeding other things
i find only 2 fuzes in my drawing
please note there are some diodes in mz wireing harness that can
cause funny readings with an ohm meter if you dont understand what there used for(this diode info may not be related to your problem)
ar dave
Users browsing this forum: Google [Bot] and 9 guests
