electrics
electrics
Postby fishface » Mon Dec 12, 2005 12:00 pm
Hi Guys
Being new to the group i have a question. Just purchased mz mastiff 2000 model, out riding friday it just stopped no electrics at all ,checked battery full power, terminals bit corroded but ok. Checked the 4 fuses all seem ok has any one got any advice?
fishface
Postby basser23 » Mon Dec 12, 2005 12:59 pm
You may have hit the kill switch on the right
handle bar.....
basser23
fuze
Postby DAVID THOMPSON » Mon Dec 12, 2005 1:38 pm
always check fuze with a load some times they look good
but and ohm meter also lies
use a bulb and battery to check them
the oem battries were crap see keith's post below
and the replacement
by someone else later may not be much better
it may show 12volts or more but has no guts when cranking
my bikes run from the main battery and i crank from a second battery
mounted in a saddle bag both are charged by the bike but are seperate
from each other
Last edited by DAVID THOMPSON on Mon Dec 12, 2005 5:44 pm, edited 1 time in total.
Postby fishface » Mon Dec 12, 2005 3:41 pm
Thanks for replies people but I mean no lights,no power,nothing.Are there any more fuses hidden, wiring is very poor compared to my firestorm.
fishface
Postby BRAAAP ! » Mon Dec 12, 2005 3:51 pm
I'm having the same problem, failed on the way home tonight, running ok, hit the turn signal and the whole bikeshut down (not fun in the dark)
started straight away after. . .
Also the bike occasionally stalls shortly after starting, letting it run for a while then switch the lights on and it dies, try it again and its ok. . .
possibly related to the left hand switch gear, lights / indicator etc. . . ?
all fuses are ok. . .
given it a good dose of ACF50
Intermittent electrical faults are the worst :?
two wheels good, four wheels bad. . . .
BRAAAP !
Postby keithcross » Mon Dec 12, 2005 5:35 pm
Check your battery, the ones MZ supply are about as reliable as the Titanics return voyage.
Postby fishface » Mon Dec 12, 2005 5:57 pm
Checked battery seems fine are there any more fuses???? also tried jumping from another source.still no lights!!!!!
fishface
ck
Postby DAVID THOMPSON » Mon Dec 12, 2005 9:02 pm
i have ran into many weird problems on bike electric
check the lugs on both posative and negative wires at the battery
and the ground wire some thing has come loose or maybe a break
inside 1 of the wires i would look at the ground wires from battery to motor first and 1 time the ground lug to wire connection was bad
it's a bit hard to trouble shoot one 3000miles away the leads on the
volt meter are way toooo short :-D
when you find it let me know what it was so i know where tell others to look next time
Postby phlat65 » Mon Dec 12, 2005 10:51 pm
disconnect and clean the ignition switch connector. terminal corrosion can be funny, it will carry the load until that little bit extra, then go open. all the current goes through the switch, would be best to convert to a load reduction relay system. I will look at the wiring diagram and come up with a detailed conversion...
Postby LWS66 » Mon Dec 12, 2005 11:25 pm
If I may add.....I'm not familiar with those bikes, but I would assume that behind the headlight/under the gauges you have various harness plug connectors? You may want to pull each one at a time....and check/clean the terminals. Sounds like main power is being intermitantly cut off to the ignition switch. Have you ridin it in the rain at all? Or previous owner?
On my Laverda I had a similar problem. Was running fine. Came to a stop, turned off for a while, went to start and no power what-so-ever. Turned the handlebars hard left and right for the hell of it and I got power back. Started pulling the plugs and found two terminals with some corrosion. Cleaned them and problem fixed. :-D
LWS66
Postby fishface » Tue Dec 13, 2005 4:22 am
Nice to have some advice, going to take ignition switch to pieces,but still need question answering about fuses!!!!.The whole wiring loom to say the bike is only 5 years old looks trashed.Tried a different battery so eliminated that. Its a pity your voltmeter leads wont stretch!!!!!! .Spoke to bike dealers in sheffield, tell them what problem is then what type of bike and wait for them to burst out laughing, what bike? an MZ sorry m8 can"t get parts for that.please keep offering advice guys.
fishface
Postby F0ul_Oli » Tue Dec 13, 2005 12:22 pm
fishface wrote:Spoke to bike dealers in sheffield, tell them what problem is then what type of bike and wait for them to burst out laughing, what bike? an MZ sorry m8 can"t get parts for that
You need to find some bike dealers who know something about bikes!!
Tell them its got a Yamaha XTZ660 Engine in it, and theyĺl soon find the parts you need!
As for the electrics, I m going to look over mine tonight as the indicators have stopped flashing, I might find the info you need.
F0ul
F0ul_Oli
Postby BRAAAP ! » Tue Dec 13, 2005 4:45 pm
if your close to sheffield try going to pleasley motorcyles (mz dealer) near mansfield
http://www.pleasleymotorcycles.co.uk/index.htm
VERY good for advice and spares. . .
on further investigation on my baggy cutting out , i think it might be the ignition relay.. or possibly the ignition barrel
its ok with the lights off, but put them on and everything cuts out (sometimes) then the neutral light has been flickering too. . .
will keep you posted and hopefully we will get them sorted !
BRAAAP !
Postby keithcross » Tue Dec 13, 2005 5:51 pm
This sounds like the problem I had this summer. Turned out to be the wires connected to the ignition switch. They finally broke off on Salisbury Plain, while have a little sorty on my own while others on teh ride out had a break. I had to fit a new switch in the end. Still at least you only have to replace the electrical part that ataches to the ignition switch barrel. BSA Regal had one in stock. Ordered one morning and the new one arived in the post the next day.
Check the wires where they are soldered to the switch first though.
Postby fishface » Wed Dec 14, 2005 5:48 am
Hi Guys found the fault.It turns out to be the ignition switch, stripped the wires back past to where they pass the frame. The red power lead that comes off had got chopped, reconnected and HEY PRESTO, all working again.Going to replace the wires properly with better quality stuff so it wont happen again. Thanks for all your replies, will use this site regularly from now on and all you people have a safe christmas
Bob
fishface
Users browsing this forum: No registered users and 231 guests
