by Jay Bee » Thu Jan 25, 2024 5:00 am
mick wrote: Strange if this is from the factory.
It isn't - see also dave47's comment above.
If MZ had used such a resistor they certainly would not have mounted it inside the air box.
What is the resistor connected to, electrically ?
Jay Bee on Fri Jan 26, 2024 8:24 am, edited 1 time in total.
Jay Bee
by mick » Thu Jan 25, 2024 10:41 am
It was not connected to anything, it sat inside the housing without any wires poking through outside of the housing, I found it after talking the housing apart.
I cannot find any description in wiring diagram.
mick
by DAVID THOMPSON » Thu Jan 25, 2024 8:08 pm
IT CONTROLS CURRENT FLOW USUALLY MAY BE THERE LEFT BEHIND BY A PAST OWNER
LEAVE IT OUT IF NOT FOUND ON ANY DRAWINGS
- Moderator
by mick » Fri Jan 26, 2024 9:16 am
Thanks for the info on this strange component, I have installed it back in the cover and blocked the two holes up with loctited bolts and used a anaerobic Loctite between the housing halves to seal up the filter housing to give it the best shot at clean air to the engine.
mick
