Captbarb wrote:This is the plug colour after a test ride tonight and sorting out my bogging down at 5000rpm now it revs great I moved the needle to.postion four and raised the float height to 27 mm from 25 mm what do you think to the colour of the plug .
Oh and this is still running on putolene synthetic mx5 1:33 .
burudi wrote:Captbarb wrote:This is the plug colour after a test ride tonight and sorting out my bogging down at 5000rpm now it revs great I moved the needle to.postion four and raised the float height to 27 mm from 25 mm what do you think to the colour of the plug .
It is clearly poor fuel supply. The correct color is coffee with milk.
Poor gasoline-air mixture is the most dangerous since it greatly raises the temperature and is prone to seizure.
Blurredman wrote:It will run weaker, but from 1-2%. It's nothing.
I've run pre-mix on both my ETZ's without rejetting, for collectively 37,000 miles. The original ETZ250 service manual gives the same size jets and makes no note at all between the pre-mix and the injection model.
Users browsing this forum: No registered users and 236 guests
