Ts250/1 quick wiring question
Postby Captbarb » Wed Sep 13, 2023 1:32 pm
Hi just putting my headlamp back after restoration I cut the wiring in the headlamp and have been splicing back together the thing is I have the wires coming from the left hand flasher unit button and I have five wires I have a brown left over and assume it's to go to the earth at the bottom of the headlight any thoughts just can't remember and struggling to read wiring diagram.
Captbarb
Captbarb
Re: Ts250/1 quick wiring question
Postby Blurredman » Thu Sep 14, 2023 2:13 am
Which diagramme are you reading?
1987 MZ ETZ300 - 38,000 miles
Postby breakwellmz » Thu Sep 14, 2023 3:25 am
[quote="Blurredman"]Which diagramme are you reading?
Image[/quo
Now that`s a wiring diagram style I like!
Postby Blurredman » Fri Sep 15, 2023 2:34 am
Yeah. These official MZ wiring diagrammes are so much easier to follow than 'traditional' wiring diagrammes.
Postby Captbarb » Fri Sep 15, 2023 12:19 pm
Thanks for that diagram fantastic in a nutshell I had wired the main brown in the loom to the ignition switch but it should have gone to the earth in the headlight and the the smaller brown that comes into the headlight with the headlamp feeds goes to the the ignition switch problem solved thanks mzers.
Captbarb
Captbarb
Users browsing this forum: No registered users and 248 guests
