Too long speedometer cable causing bouncing needle?
Postby klemmy » Thu Jun 22, 2023 1:42 pm
Anyone had simmilar issues?
I'm having bouncing needle in the speedometer since i own my ETZ 250. I had tried many things, lubed the wire, lubed driving mechanism in the rear wheel, adjusting cable to have the "smoothest" position to run...I put a new (used) speedometer, it is the same situation, the needle is bouncing up to 70-90km/H beyond that is ok. I tested speedometer with cordless drill and it picked up speed very smoothly and without any bouncing. But when I disconected cable from driving mechanism and drive it with cordless drill ,it is bouncing again. So I think there is a problem in the cable.
The cable itself is looking pretty new...
Any suggestions? Shound I trimmed the end of the cable, the square one?
Thank you very much for your answers
klemmy
Re: Too long speedometer cable causing bouncing needle?
Postby DAVID THOMPSON » Fri Jun 23, 2023 12:21 am
bur on cable it binds an releases giving false reading
Postby JawasandMZs » Tue Jun 27, 2023 2:06 pm
MZs speedos at best aren't super accurate. I use a magnetic bike speedo alongside the normal speedo (called cateye quick) for a spot-on reading hence reassurance in these days of 20 limits.
It's small discreet and easy fit. They cost £30. Downside: goes haywire above 53mph and not back-lit.
JawasandMZs
Postby DAVID THOMPSON » Tue Jun 27, 2023 3:16 pm
they make GPS units for boats but most only show to 60 mph and do not display miles traveled
but looks like amazon has a bunch of listings
https://www.amazon.com/gps-speedometer- ... motorcycle
DAVE
Postby klemmy » Wed Jun 28, 2023 7:56 am
Problem solved.
It turned out, that the cable was problem at the end of ballade...
New better quality cable is fitted and now it works fine :D
klemmy
Users browsing this forum: Bing [Bot] and 157 guests
