Relays
Relays
Postby Mach IV » Wed Nov 23, 2022 4:15 pm
I'm assuming each headlight has its own relay,the low beam and high beams
have individual color codes.
I have the low beam out on the right(throttle side) and it's not the bulb,I swapped the plugs
and left went out.
The fuses are marked but the relays are not.
I did a search on relays and nothing relevant came up.
Anyone know which relays go to what?
Mach IV
Re: Relays
Postby Mach IV » Wed Nov 23, 2022 10:51 pm
I pulled all the relays and tested them,all good but
something still amiss.
Could be handlebar switches.
Mach IV
Re: Relays
Postby silver MZ-1000s » Thu Nov 24, 2022 10:31 am
If it is a switch and you cant fix it , Look for switch from Aprilia Futura . Same thing , left and right side of clipons .
silver MZ-1000s
Re: Relays
Postby silver MZ-1000s » Thu Nov 24, 2022 10:35 am
silver MZ-1000s
Re: Relays
Postby Mach IV » Thu Nov 24, 2022 12:18 pm
Thanks for the info.
I'm going to resolder joints and check it w/a meter and see.
Flying blind without a wiring diagram,it'll just take more time.
Mach IV
Re: Relays
Postby Mach IV » Thu Nov 24, 2022 3:28 pm
Cleaned up the switch after disassembly, hit the solder joints again and problem remains.
Only high beam to work is the right one,flash to pass or high beams on and the low beam on the right still doesn't work.
There has to be a module or relay for the headlights somewhere besides the fuse panel.
Mach IV
Re: Relays
Postby silver MZ-1000s » Thu Nov 24, 2022 4:04 pm
I doubt there is anything else in that electrical system than those that you point out . Grab the tester and find out what are you missing at the socket is it + or _ , than chasse the wire , nothing to it lol.
silver MZ-1000s
Re: Relays
Postby silver MZ-1000s » Thu Nov 24, 2022 4:10 pm
Did you measure the incoming and outgoing voltage at the switch ? Is it coming to the switch at all ? Do you have continuity tester or you just guessing ? Same for every componnent in that circut .
silver MZ-1000s
Re: Relays
Postby Mach IV » Thu Nov 24, 2022 4:17 pm
It's not just a wire,it's got to be a relay or module.
The plugs are fine,sprayed with contact cleaner and lubed w/die electric grease.
I'm still not sure which relays are for the headlights.
If I knew I could swap them and see if the problem changes lights.
Mach IV
Re: Relays
Postby silver MZ-1000s » Thu Nov 24, 2022 4:53 pm
One more time , do you have continuity tester with low voltage scale ? If you dont know how to use the tester , i doubt the electrical diagram will help you much , yes one of those relays must be for lights , and there is only 4 or 5 of them in the fusebox , so idk how hard is it to chceck what is for by pulling the relas one by one while bike is working . Come on ! Its just a running light . I think you going to neeed a mechanic lol .
silver MZ-1000s
Re: Relays
Postby Mach IV » Thu Nov 24, 2022 4:59 pm
silver MZ-1000s wrote:One more time , do you have continuity tester with low voltage scale ? If you dont know how to use the tester , i doubt the electrical diagram will help you much , yes one of those relays must be for lights , and there is only 4 or 5 of them in the fusebox , so idk how hard is it to chceck what is for by pulling the relas one by one while bike is working . Come on ! Its just a running light . I think you going to neeed a mechanic lol .
I know WTF I'm doing.
If I don't know what the readings should be how the fuck can I diagnose it?
Mechanics are horrible with wiring.
I'm not pulling relays w/the key on without know what they are for, you sound like a mechanic.
Mach IV
Re: Relays
Postby silver MZ-1000s » Thu Nov 24, 2022 5:13 pm
Im a electrican by trade , and yes i would pull the relays while bike is working lol. And if you know WTF you are doing ! Than whats the fuss ?
silver MZ-1000s
Re: Relays
Postby Mach IV » Thu Nov 24, 2022 9:53 pm
silver MZ-1000s wrote:Im a electrican by trade , and yes i would pull the relays while bike is working lol. And if you know WTF you are doing ! Than whats the fuss ?
An electrician and 12v are worse than a mechanic & 12v. :lol:
4 colors of wire vs. hundreds of solid, striped,dashed and combinations.
I'm not familiar w/ the bike or the system, not interested in toasting the ECM on
a bike I can hardly get stick coils for.
I don't remember if both the lows should be on and only one high comes on.
Some Japanese imports are set up like that so maybe this is also.
I think it looks bad and if that's the case,maybe I'll convert it.
I do lots of custom jobs/builds and make my own harnesses.
Mach IV
Re: Relays
Postby silver MZ-1000s » Thu Nov 24, 2022 11:26 pm
Do me a favor , find the problem and report back of your faindings . Instead of looking up all of those fancy drawings get the tester and do the job . Will be waiting .
Last edited by silver MZ-1000s on Fri Nov 25, 2022 12:31 am, edited 1 time in total.
silver MZ-1000s
Re: Relays
Postby silver MZ-1000s » Thu Nov 24, 2022 11:33 pm
I dont remember if MZ does shut of the lights during the start but that may have something to do with your problem , also ignition switch . Look there .
Last edited by silver MZ-1000s on Fri Nov 25, 2022 12:29 am, edited 1 time in total.
silver MZ-1000s
Return to 1000S
Users browsing this forum: Bing [Bot] and 10 guests
