Ignition Cylinder for 97 Skorpion
Postby Javier_flow_88 » Fri Nov 15, 2013 7:20 pm
Hello everyone,
Kinda new to the forum, looking for help in obtaining a new ignition cylinder (and brand new set of keys I suppose) for a 97 Skorpion.
Browsed the forum, found out the ILCO key x270-tmc1 would match the size, asked a locksmith to get it done...couldn't get it done :cry: Mentioned that it may be broken inside.
Would anyone know an interchangeable part for the ignition cylinder? I know the brand is a ZADI, and on the back its written PF385.
Had found some infor in the forums for ignition switches for a Baghira (ZADI Q933) from a BMW F650 1999. I thought that there may be something similar for the Skorpion...
Thanks,
Javier
ignition_cylinder_bottom
ignition_cylinder_top
97 MZ Skorpion Tour 660cc
Javier_flow_88
Re: Ignition Cylinder for 97 Skorpion
Postby mincehead » Fri Nov 15, 2013 7:28 pm
What`s wrong with the old one?
mincehead
Postby DAVID THOMPSON » Fri Nov 15, 2013 10:02 pm
i think its bound up with a broken key inside
i have worked on 3 Buell bikes with key problems all had the key broken off in them
Postby Javier_flow_88 » Tue Nov 26, 2013 9:20 pm
Hello,
From what the locksmith mentioned, it's broken inside and could not create a key. Looking for a new ignition or a similar one of size to perhaps rewire it to the bike.
Javier
Javier_flow_88
Postby Linegeist » Wed Nov 27, 2013 6:49 am
FWIW, I've removed 3 broken ignition keys in the last few years for various folks, 2 in cars and 1 in a bike, by the simple expedient of using a tiny dab of araldite on the broken stub, and then inserting it into the barrel so it snugly contacts the broken piece. Leaving it for 24hrs to give it a fighting chance of holding, has resulted in a successful (if gentle) withdrawal of the whole key shaft each time.
On the basis that the barrel's pretty much hors d'combat anyway - I suggest you've nothing much to lose by giving this a try .........................
Linegeist
Postby basser23 » Wed Nov 27, 2013 7:19 am
moto guzzi uses a similar if not exact one.I have done this on my Skorpion,just the lower switch half though....may still have the key cylinder ...I'll have a look
basser23
Postby Hooperman999 » Mon Jul 16, 2018 9:38 am
Appreciate this was ages ago, but did anyone find out what the electronic part of the MZ 660 ignition switch has also been used for or what other one could be used?
Hooperman999
Postby Nils D » Tue Aug 14, 2018 8:31 am
It's made by ZADI.
I think it's a quiet standardized unit that could be found on various bikes.
I have an old one that you could have, but one cable is cut near the very unit, but I think it should be possible to open it up and to solder on a new cable.
Skorpion Traveller 96
Nils D
Postby DAVID THOMPSON » Tue Aug 14, 2018 11:55 am
search window for keyskeys all one word in search window for site above
will show list of a bunch of bikes that use these keys
Postby Rizla215 » Sun Jun 26, 2022 9:54 pm
Any word on getting a key switch part#? I’m in the middle of a rebuild & it’s the one aspect keeping me from moving forward. I’ve seen lots of posts about keys.. but no info on the keyswitch. Thanks,
B
Rizla215
Postby DAVID THOMPSON » Mon Jun 27, 2022 3:11 pm
Postby ralf » Wed Jul 06, 2022 1:09 am
As other advice, a lot of other bike manufacturers have used Zadi switches including some Triumphs and being Italian, Guzzi etc. Its just a matter of finding which one is the same as the Skorpion, yes, it's easier said than done. You might try taking it to a breakers to see if they have similar otherwise Motorworks (BMW) and Gutsibits (MotoGuzzi) I have found helpful. Or a Triumph dealer?
Good luck.
ralf
Users browsing this forum: Bing [Bot] and 19 guests
