TS250 Downpipe leak
Re: TS250 Downpipe leak
Postby Guesi » Wed Mar 23, 2022 5:32 am
You are right, it seems that it has been shortened.
To show the different collars, here a picture.
From left to right:
TS 125/150 and ES 125/150
TS 250
ETZ 150
ETZ 250
ETZ 251
Guesi Motorradteile
MZ spare parts
Postby Andy_C » Wed Mar 23, 2022 6:07 am
Guesi - thanks no idea there was such a range of exhaust collars.
My new one should be arriving today.
Andy_C
Postby Puffs » Thu Mar 24, 2022 3:40 am
Yes Guesi, thanks for that clarifying pic!
Postby Andy_C » Fri Mar 25, 2022 2:21 pm
It arrived today - looks exactly like the one in the picture that Kruh posted up - the second one in from the left that Guesi posted, so it is the right one.
The new one was about 5mm longer than the old one and had the small unthreaded protrusion on it, which did not exists on the old one, for whatever reason.
Put it all back together this afternoon, with a little RTV as suggested, torqued it up nice and tight.
Hopefully take it on a run over the weekend, and hopefully there will be no "spooge" (good name isnt it - the guys on the Kawasaki Triple site that I post on use that term) leakiing down the pipe.
We shall see.
Andy_C
Postby Blurredman » Fri Mar 25, 2022 5:28 pm
Good news and good luck to you! :-D I personally don't mind the oil dribble, but then the state of my bike's (in general and) exhausts means it might be beneficial to me to have oil covering the metal for further rust prevention... :lol: :lol:
Postby Puffs » Sat Mar 26, 2022 2:34 am
Postby Andy_C » Sun Mar 27, 2022 11:54 am
Took it out for a short - 5 miles or so ride this afternoon - no spooge !
Thanks once again for everyones help, bit busy with other stuff at the moment, but around about mid April I should be able to start putting some proper miles on the bike.
Seems to peform a lot better than my old ETZ used to.
Andy_C
Postby AndyP66 » Sun Mar 27, 2022 3:39 pm
I have the same problem on my 1979 TS125. So watching this thread with interest.
AndyP66
Postby Andy_C » Mon Mar 28, 2022 2:03 pm
Andy - if you look at the picture that Guesi posted up you will be able to see which collar is the right one for your bike.
Good luck.
Andy_C
Postby Puffs » Tue Mar 29, 2022 3:49 am
Postby Tankstraddler » Sun Apr 03, 2022 12:07 pm
Andy C posted a photo of his exhaust pipe. Here's a dimensioned photo of mine. Unfortunately it does not fit when mounted, being about 3/4 inch too high for the clamped silencer. Any ideas? It's a pattern part, of course, but suppliers who have been kind enough to measure their stock say that they are all like this.
Tankstraddler
Postby Puffs » Mon Apr 04, 2022 4:38 am
Postby Andy_C » Mon Apr 04, 2022 10:32 am
I would say that the header that you have has too tight a bend in it.
Looking at the picture with it fitted to your bike, it is much closer to the engine case than mine - it looks to be about half the diameter of the pipe too high.
I would say that the header is the wrong one or has been bent at some point in it's life.
Best bet would be to see if the MZ shop or E bay has one.
Cheers.
Andy_C
Postby Puffs » Tue Apr 12, 2022 3:11 am
It had slipped my mind, but a similar TS header issue came up earlier: viewtopic.php?f=20&t=11790&start=15
Previous
