Bits and bobs
Re: Bits and bobs
Postby Gerryman Ts125 » Wed Feb 02, 2022 6:20 am
Puffs wrote:It's a pity you sold your TS. Don't you feel the urge to get another MZ?
Cruising to Fort William on a summer day...
If I got another Mz, it would be a four stroke. Or I would make it one. If it was a TS,
I would put a half decent disc brake front end on it, and put one of my many Ar 125 engines and wiring loom on it and have some fun. In Scotlands back roads.. As they say ' where the is a Willie, there is a way ' .
Gerryman Ts125
Re: Bits and bobs
Postby Puffs » Thu Feb 03, 2022 4:22 am
So who is going to let out to Willie that spring is coming...
Re: Bits and bobs
Postby Blurredman » Thu Feb 03, 2022 3:33 pm
So i've dug the plate out that I have spare.. Which I do believe came with a TS250 wheel (but i've no way to tell, that wheel has been sold).
It is 22-24-278.
Is this the correct one that is needed? Though the 'inbuilt' spacer on the outter side doesn't look as long as those I've seen on-line, but according to the sheets I see, they look interchangable to a certain extent. Anyway, I'm not sure the spindle accross these models are the same diameter- I imagine they are, but I measured it anyway and it is 14.95mm.
Re: Bits and bobs
Postby Puffs » Fri Feb 04, 2022 5:44 am
Re: Bits and bobs
Postby Gerryman Ts125 » Fri Feb 04, 2022 6:58 pm
Looks the same as my one. Mines was polished. But the inside just looked like this one. Can't remember off hand what the numbers on the inside were. Can't be that far off though
If this is the part he is taking about. He knows where you are.
Gerryman Ts125
Re: Bits and bobs
Postby dave47 » Sat Feb 05, 2022 4:05 am
I've noticed that this part has been lost or discarded from many TS bikes, and replaced by a spacer. Does anybody know why? Is it a styling thing or functional, or do they just get separated from the wheel in storage?
dave47
Re: Bits and bobs
Postby Puffs » Sat Feb 05, 2022 4:20 am
Re: Bits and bobs
Postby dave47 » Sat Feb 05, 2022 5:47 am
Ok, I was wrong. It is the correct part.
dave47
Re: Bits and bobs
Postby Puffs » Sun Feb 06, 2022 6:23 am
Re: Bits and bobs
Postby Blurredman » Mon Feb 14, 2022 10:34 am
The question is.. does the OP want to purchase mine? :)
Re: Bits and bobs
Postby Puffs » Mon Feb 14, 2022 11:32 am
Re: Bits and bobs
Postby Gerryman Ts125 » Mon Feb 14, 2022 1:48 pm
I wonder is it just as rusty. Or is it reconditioned. And only needs a seat, barrel and hubcap. Over to you Meph.
Gerryman Ts125
Previous
Users browsing this forum: No registered users and 35 guests
