dave47 wrote:I looked at a youtube video for an es150 engine restoration and a very competent looking person was using a 13mm gauge (12.97), rather than 16.1mm.
Checking further, there are two mz manuals for the es150, the early one says 16.1 and the later 13mm.
The Haynes manual wrongly copies the details from the earlier manual for both ES and TS, although the accompanying photo seems to show a vernier on 13mm.
This may relate to two different engines, both fitted to the ES, the early engine with a single chain, and the later one with a duplex.
If yours has the duplex, it might be as well to go with 13mm?????
Puffs wrote:Ooooiihh...! It looks gorgeous!
Congratulations with the result & your work.
But: what was it? Which of the issues you found caused all the hassle?
Blurredman wrote:Congratulations! I bet you can't wait to go for a ride.
Question: Is that left rear shock on the correct side of the swingarm at the lower mount? I often see people put it this way you have (or previous owner has) but it looks a bit odd to me- surely it should be mounted on the outside of the swingarm, even on this model of bike?
Users browsing this forum: No registered users and 202 guests
