MZ ES 250/1 electrical , spark plug, ignition and charging
Re: MZ ES 250/1 electrical , spark plug, ignition and chargi
Postby grimstone » Fri Oct 08, 2021 4:24 am
Hello,
Thanks for the reply and it really helped.
When you work late in the night, you are stupid and do stuff incorrectly this is what happens. When I pressed the rotor in the woodruff key got dislocated and ...... what alignment..... I dismantled again today and found that key sitting in the armature of the rotor :).....
Will redo all the assembly and retry. Keep you posted
______________________________________________
MZ ES 250/1 1962 restoration
TRIUMF TS100 HERREN MOFA 98cc restoration project
BMW F650GS 2001 with lots of mods
grimstone
Postby grimstone » Fri Oct 08, 2021 10:19 am
It starts perfectly and idles fine with a fixed advance of 3,6 but it kicks if you are not commited on that pedal :)). Now when trying to revv it, it boggs ... maibe too much advance.... or crappy Romanian Carb...
I will try to setup the advance at 3,3 to see how it behaves. Centrifugal mechanism is locked open all the way now but I do not think it is necessary.
grimstone
Postby Puffs » Sat Oct 09, 2021 4:27 am
Postby grimstone » Mon Oct 11, 2021 3:18 am
Yep,
I will revert to standard settings, as I saw that the play is ok on that mechanism.
Fitting the mikuni: Can someoane measure the inside of the clamp style intake manifold, the part that fits over the carb, (as it is on the ETZ250), because the plan is, if it has the right inner diameter, to cut that part and weld it on the intake of the es or maibe i can use the etz intake directly.
More thoughts on the ignition: as the light is very poor The VAPE 12V modification will come sooner that planned, now it is just a matter of redirecting some cash from other projects :)
grimstone
Postby Puffs » Mon Oct 11, 2021 4:31 am
Postby Blurredman » Thu Dec 09, 2021 7:33 am
Did you ever get any further with this 'project' Grimstone? 8)
Previous
Users browsing this forum: No registered users and 43 guests
