TS250 Footrest Rubbers
Postby Andy_C » Sat Sep 25, 2021 11:40 am
Might be a daft question, but how do you replace them?
Cut off the old ones and push the new ones on?
As the footrest pivots appear to be riveted in place I dont see any other way.
Andy_C
Re: TS250 Footrest Rubbers
Postby DAVID THOMPSON » Sat Sep 25, 2021 7:33 pm
put some liquid soap or brake fluid in them and they will push on a lot better
Postby Andy_C » Sat Oct 02, 2021 10:47 am
Sorry meant to have said, pillion footrest rubbers.
I have since found out that you cannot buy pillion footrest rubbers (at least I have been unable to find any), I found that rider footrest rubbers fit, all you have to do is knock the pin out of the footrest pivot, throw the old rubber away, and cut down the rider rubbers to open the end then cut the other end back to the end of the cutout.
The rubber then slides nicely over the footrest tube, then you re fit the pin and re expand the end.
Job done.
Andy_C
Postby Gerryman Ts125 » Sat Oct 02, 2021 1:06 pm
If you take the pillion footrests off, stick them in a vice you can drift the footrests out and off. Sometimes compressing the footrest (in situ) and someone else can drift them out on the bike. First way is less disruptive though. If the pins are unusable after drifting them out, if no replacement is available. You can use a 10mm short nuts and bolts.
Gerryman Ts125
Postby Puffs » Sun Oct 03, 2021 4:28 am
Postby Andy_C » Sun Oct 03, 2021 2:01 pm
Puffs - of course you can replace the whole thing, but replacing just the rubbers is cheaper :mrgreen:
Andy_C
Postby Puffs » Mon Oct 04, 2021 3:16 am
But then I have an even cheaper & easier solution for you: just take'em off!
Postby Andy_C » Mon Oct 04, 2021 6:14 am
:-D :-D
Andy_C
