Andy_C wrote:Fitting a new kickstart cotter pin has moved the engagement point of the kickstart a little - the old pin looked it was the wrong size and was pretty "mashed" where it contacted the kickstart shaft, ended up drilling it out, then collapsing it in on itself to get it out, I have noticed a lot of wear on the kickstart pedal causing the pedal not ot be horizontal, I plan to build it back up with a little weld.
Users browsing this forum: Bing [Bot], Gerryman Ts125 and 10 guests
