50:1 or 33:1
50:1 or 33:1
Postby Andy_C » Sat Jun 05, 2021 3:19 am
Seems to be some differing opinions regarding petrol / oil mix for the TS 250.
Seems that some swear by 33:1, others by the recommended 50:1 which is what I was planning to use.
In the last 40 years since the bike was made I am sure that oil technology has improved and a modern semi synth (which is what I used to use in my ETZ) will be just fine at 50:1
Any thoughts?
Andy_C
Re: 50:1 or 33:1
Postby Puffs » Sat Jun 05, 2021 5:30 am
Re: 50:1 or 33:1
Postby Andy_C » Sun Jun 06, 2021 2:05 pm
Yep - factory recommendation for the TS250/1 is 50:1 and I plan to use the same oil as I use iin my Kawasaki Triple, and as I think I said used to use in the ETZ.
Quite tempting to follow you and go for 40:1 just for peace of mind.
As you say modern Semi - Synth oils are pretty much smokless these days.
Andy_C
Re: 50:1 or 33:1
Postby Guesi » Sun Jun 06, 2021 11:58 pm
MZ recommended 1: 50 for the TS and ETZ Models.
So nowadays with the better 2-stroke oils than in the GDR 1:40 is far to much oil...
And as always: More is not always better :-)
Here in Germany many MZ drivers have rations with about 1:60 or 1:70 without any problems.
MZ allowed 1:100 using full synthetic oil (castrol biolube then)for the ETZ 250/251 .
Guesi Motorradteile
MZ spare parts
Re: 50:1 or 33:1
Postby Puffs » Mon Jun 07, 2021 2:45 am
Re: 50:1 or 33:1
Postby breakwellmz » Mon Jun 07, 2021 8:50 am
Too much oil makes it run weaker in terms of fuel/air, i thought someone of your vast knowledge would know that! :wink: :lol:
Re: 50:1 or 33:1
Postby Andy_C » Mon Jun 07, 2021 11:45 am
Guesi - I was thinking along those lines in that modern semi synth oils are way better that the oils of 40 years ago when these bikes were built.
I was thinking that perhaps going to 40:1 might give a little more protection, but if the ETZs are running at 50:1 that is what I'll stick with as I used to run my old ETZ pretty hard with no problems.
Andy_C
Re: 50:1 or 33:1
Postby Puffs » Tue Jun 08, 2021 5:04 am
Re: 50:1 or 33:1
Postby Blurredman » Wed Jun 09, 2021 2:48 am
breakwellmz wrote:Too much oil makes it run weaker in terms of fuel/air, i thought someone of your vast knowledge would know that! :wink: :lol:
Although that is true, I've now put 14k on one bike, and 18k on another and not re-jetted. I did the calculations at the time for 30:1 and the margin is so small it just doesn't matter.
Infact, the jets for the pre-mix vs injection etz 250's are the same. I know at a recommended 50:1 it's more in line with the pump, but alas the pump is directed straight into the barrel. In the official service manual, no distinction is made between the two.
Re: 50:1 or 33:1
Postby Puffs » Wed Jun 09, 2021 4:03 am
Users browsing this forum: No registered users and 35 guests
