Water pump seal
Water pump seal
Postby Señor Willy » Mon Dec 07, 2020 12:04 pm
Would someone be able to tell me if this seal fits my mastiff please?
https://www.cmsnl.com/products/sealmech ... 1h1243810/
Señor Willy
Re: Water pump seal
Postby breakwellmz » Tue Dec 08, 2020 7:42 am
That`s for the later 4-valve fuel injection engine.
Often if you put in XTZ660 to a search you will be given results for XT660Z which is not the same engine.
Can you get to a Yamaha dealer?
Re: Water pump seal
Postby Señor Willy » Tue Dec 08, 2020 9:50 am
Unfortunately not.
Graham's (UK mz dealer)said the water pump isn't available anymore and said that seal might do but weren't sure.
I'm trying to order online but getting nothing.
Señor Willy
Re: Water pump seal
Postby breakwellmz » Tue Dec 08, 2020 10:01 am
Forget Grahams it`s a Yamaha suppliers you want.
Join and enquire on a Yamaha forum maybe?
Re: Water pump seal
Postby Señor Willy » Tue Dec 08, 2020 1:29 pm
This is the pump for a 1995 SZR660.
Should be the same yeah??
Is it these 2 seals failing that cause leak out the weep hole?
Señor Willy
Re: Water pump seal
Postby ralf » Fri Dec 11, 2020 10:52 am
If it's just the o rings you could measure them (ID X section) and get them off eBay? Viton is a but more expensive but generally worth it if you can locate a supplier. I've bought lots of o rings not from OEM's.
ralf
Re: Water pump seal
ralf
Re: Water pump seal
Postby Señor Willy » Fri Dec 11, 2020 10:58 am
I opened it up yesterday to see.
Looks like I need an oil seal and mechanical seal which are aren't available.
At the moment I'm trying to figure out if the ones for a Yamaha raptor will fit.
Señor Willy
Re: Water pump seal
Postby ralf » Fri Dec 11, 2020 11:03 am
If you type "water pump mechanical seal xt660" into eBay you get a load of them available, all about £25.
ralf
Re: Water pump seal
Postby breakwellmz » Fri Dec 11, 2020 4:57 pm
I`ve just done that myself and it only comes up with ones for the later 4V FI engine (XT660Z), unless they are the same, i doubt it. The other one was an O ring type gasket for the XTZ660.
Re: Water pump seal
Postby Señor Willy » Sun Dec 13, 2020 1:02 am
Looks like no. 8 and 9 here will do the job I think.
It's a 2001 grizzly but a lot of the waterpump parts have the same part no., like circlips and the dowel for the propeller shaft so hope both these seals are the same.
Also, is the mechanical seal ceramic so only non silicate coolant to be used?
Señor Willy
Re: Water pump seal
Postby Señor Willy » Wed Jan 06, 2021 2:09 pm
Just to confirm the parts for a raptor will do the job.
Parts arrived earlier and fitted perfectly.
sealseal
Señor Willy
Re: Water pump seal
Postby breakwellmz » Thu Jan 07, 2021 4:31 am
Oh well done!
That seemed harder work than it should have been though, certainly not helped by the XTZ660/XT660Z confusion.
Re: Water pump seal
Postby Señor Willy » Thu Jan 07, 2021 12:47 pm
breakwellmz wrote:Oh well done!
Easy enough when I had the right parts.
The hardest part is probably getting the shell of the old mechanical seal out as it was rusted onto the waterpump.
I heated it up and used 13mm( or was it 14mm) socket to knock it out.
I'm going to post the part numbers of the correct parts used so it may help someone in future.
Señor Willy
Re: Water pump seal
Postby Señor Willy » Thu Jan 07, 2021 1:05 pm
Genuine parts I bought were
The mechanical seal comes in two halves.
The spring half and the ceramic seal half.
The ones in the pics below with the yellow arrows pointing to them.
Oil seal is the one with the red arrow.
Then you have two o rings for the waterpump housing; the blue and green arrows.
Or you could skip all that and get one of these kits which include bearing and circlips for the shaft ( cheaper as well)
https://www.quadbikeswales.co.uk/yamaha ... d-kit.html
https://www.ebay.co.uk/itm/333768375117
Hopefully this helps someone down the line with the job.
Oh yeah, I also refilled with a non silicate coolant so more ceramic seal friendly.
Señor Willy
Users browsing this forum: Google [Bot] and 27 guests
