nice2day wrote:Many thanks for your replies Kruh and David. Its always a pleasant feeling when you find that the problem you have is shared by others on their machines.
Kruh points out that it is the rubber cup assemblies that turn in the mounting and yes, that is the same with my ones and it is not the clocks turning inside the cups as I seemed to imply in my question.
So it is just a matter of using some rubber or tape in a convenient position to fix the problem and that is simple enough. I guess the original design could have been improved if there was a small cut-out or notch in the aluminium mounting frame holes and the rubber cups were moulded with a corresponding bulge to anchor them and stop the rotation. That is very unlike MZ to have missed a simple trick like that......Thanks again
PS:
I suppose if a small hole was drilled somewhere near the back of the fame holder, a self tapping screw of selected length could be screwed in to hold the rubber cup. Just one on each clock would be enough. If the hole was small and the screw actually made its thread in the aluminium rather than the rubber, the screw point just needs to protrude only about 2mm to stop the cups rotating. The screw could then be fully tightened down flush (maybe a "countersunk" screw could be used?) and painted black. This is just an idea but I don't think I have the heart to drill my mounting frame even though the mod would not be that noticeable.
dave47 wrote:MZ didnt miss a trick; they just stopped using it. I can't remember what MZ this came from.
Users browsing this forum: Bing [Bot] and 157 guests
