nice2day wrote:Hi Chaps. Just when you think it's finished something always seems to go wrong and your weeks away from finishing. Yep. Today I refitted the carb (I think I have improved the tickover now) and thought I'd check if the petrol tap was tight. To my shock and horror it WAS leaking and had bubbled up a great big area of paint under the newly sprayed tank. I really couldn't say if had just started or had been leaking since I removed the petrol pipe a few days ago. I'm not absolutely sure but it seems the threaded tap stub might be the source of the leak so it will need re-braising and the tank completely stripped and resprayed
BUT>>>>Here is the problem...the tank was massively rusty inside (outside perfect) so I used TAPOX tank sealer. I am a great fan of this product and used it lots of times on different tanks with total long lasting success. Unfortunately what must have happened is that on tightening the tap I must have slightly rotated the stub within the tank as maybe the metal was extra thin due to corrosion. So now I have to get the leak fixed but what with the TAPOX inside, trying to use a hot flame isn't going to do this sealant any good. I was thinking that maybe TIG BRAISING might be possible? (thoughts on this?)
I also considered that to get a firmer stronger fixing it might be better to make up a new male threaded fitting in the shape of an inverted top hat so that the wide flange of the fitting (about 22-25mm in diam?) could be TIG welded to the bottom surface of the tank after the original stub had been removed. At least there is good metal surrounding the hole. This would avoid the original threaded tube (stub) simply twisting again when tightening the tap.
Any thoughts or personal stories on these tanks?...Much obliged for your ear as ever...All the best.
Les
Puffs wrote:Brazed or welded then; my life will be so much better knowing this, and now Les will know exactly what to do. Thanks breakwellmz!
On the topic, my fear is indeed too that corrosion is more widespread. Then more drastic measures may be required.
Users browsing this forum: No registered users and 238 guests
