ETZ250 front brake
ETZ250 front brake
Postby tigcraft » Sat Sep 12, 2020 4:45 am
Can anyone tell me what the gap is supposed to be between the front disc and leg as mine is uncomfortably close?
tigcraft
Re: ETZ250 front brake
Postby Blurredman » Sat Sep 12, 2020 5:27 am
I've also looked for such info and never found...
Both my bikes the discs are so close you'd swear they were touching!
Postby tigcraft » Sat Sep 12, 2020 1:44 pm
Probably not what I wanted to read but I think your bikes are correct in how they should be therefore mine must be right too as it’s the same.
tigcraft
Postby Puffs » Sun Sep 13, 2020 4:54 am
A 0.95mm feeler passes easily between the fork leg and the support part of the disk on my 251 (which I believe is the same as the 250).
Postby tigcraft » Sun Sep 13, 2020 5:33 am
Ok so mines about right. Why on earth would any bike maker build something with nearly zero clearance beats me best of all MZ?
tigcraft
Postby DAVID THOMPSON » Sun Sep 13, 2020 8:50 am
the boys did not want to build a whole new fork
they wanted to fit a disk
and it worked with out a new wider set of fork clamps a longer axle and spacers for the front fender
do not get a plastic shopping bag caught in it at speed :smt023
Postby tigcraft » Sun Sep 13, 2020 4:06 pm
Even with that I still scratch my head.
tigcraft
Postby Puffs » Mon Sep 14, 2020 3:45 am
Good question. Maybe there is an engineering reason, for instance that the farther you offset the disk from the fork leg, the more torsion torque (trying to rotate the fork around the length axis) it gets. True, that axle is a bit thin, but even so, quite massive & heavy. Maybe they calculated in that direction and choose this small offset?
Indeed, elsewhere you see more, from reputable manufacturers, and such a small gap would give problems offroad. But all the other bikes I looked at have much bigger D hollow axles.
Postby dave47 » Mon Sep 14, 2020 5:53 am
They must have just figured a gap is a gap.
For road use it only becomes a problem if corrosion sets in between the steel disk and the alloy holder. It forces the alloy to rise and foul the fork leg, so you need to keep the junction protected with paint.
dave47
