Mz 125sx not turning on nothing turns on
ANYONE(no registration necessary) can post here to comment on the site, offer suggestions, or seek help with registration process.
Postby noahr1234 » Sat Aug 22, 2020 9:15 pm
Hi, i was messing with my 2002 Mz 125sx motorcycle recently and for some reason now the bike wont turn on, i checked the fuses they're all good, i think i may of blown something just don't know what, does anyone have any idea what could of happen?
noahr1234
Re: Mz 125sx not turning on nothing turns on
Postby DAVID THOMPSON » Sat Aug 22, 2020 11:38 pm
check the red black wire and red/white wire with a volt meter at the relay 19 /30 main relay
at least 1 will have 12volts both should have 12v with key on ..check if bike is in gear
green wire on relay goes to neutral on motor
i have had a lot of loose spade lugs
link to wiring drawing it is almost the same for 125 or 660
viewtopic.php?f=3&t=8937&p=46430&hilit=ing%2Astart#p46430
Postby DAVID THOMPSON » Sun Aug 23, 2020 3:46 pm
also
make sure bike is in neutral and kill button on handle bar is in run
Postby noahr1234 » Sun Aug 23, 2020 3:55 pm
Ok thank you so much! ill try this but this is if the bike gages wont turn on and no lights right?
noahr1234
Return to Suggestion/Comments Box
