jpmsteadi wrote:So the new plug helped the low speed hesitation, but did not cure the current problem. bike ran great until it got up to temp, about 6 mins this time and the problem happened again. Looking at the AFR gauge when its happening, it seems like its just slowly going lean/not combusting (a misfire also looks like a lean mixture since the oxygen is still present). I felt the coil and it seemed not too hot, but playing with the connections on it seemed to help temporarily. I have replaced those spade connectors once before when they were slipping off, but I will inspect them again.
I have the nicer CDI ignition system coming from bill in germany, but the package tracking says that it is held up in NY right now for some reason. It, along with the new rectifier, will essentially just have a new electronics system.
Also when I installed the new plug I went back to the base level jetting (40, 155, EMR needle at clip 5 from bottom) and the AFR readings were better. I can still go leaner, which is interesting. But I don't really want to keep pushing the bike home, haha
jpmsteadi wrote:Here is one more picture closer of where the thermostat ends up.
Initially I was thinking I would need to build or 3d print a bracket for it, but it seems to be very well held in by the hoses, the oil return line from the head, and the clutch cable.
Puffs wrote:That seems like a worthwhile visit!
On using both disks/rotors: if you use only 1, all the torque from the braking will only be stopped by 1 single fork leg. That may cause extra wear, as well as torsion in the forks. Sometimes you see a brace between the 2 legs to combat that.
It's your bike, but I would very much prefer using both disks. Even though it's a bit of extra weight.
breakwellmz wrote:jpmsteadi wrote:Here is one more picture closer of where the thermostat ends up.
I received this via Ebay today but think it`s final resting place will be a bit different to yours due to the hi-level header pipes on mine, we shall see. -
https://www.ebay.co.uk/itm/Ktm-RC-390-R ... 2749.l2649
Users browsing this forum: No registered users and 167 guests
