6 volt regulator
6 volt regulator
Postby richardh » Mon Jan 27, 2020 2:28 pm
Es150/1 1970
I am needing a new regulator and will probably be a solid state one.
Do I need to keep the wire resistor coil in the dynamo or just the 2 wires going down to the BRUSHES
Thank you
richardh
Re: 6 volt regulator
Postby Guesi » Mon Jan 27, 2020 4:04 pm
This will tell you the installation guide when you buy one.
Guesi Motorradteile
MZ spare parts
Postby DARKEST » Tue Jan 28, 2020 3:23 am
Hi richardh
I have with success installed a R81 VAPE on my MZ TS250 74'. Yes, the resistor have to go with this type of regulator. As Guesi correctly says it should be told in the installation guide following the regulator as it did with mine.
/Brian
DARKEST
Postby richardh » Tue Jan 28, 2020 3:05 pm
Thank you all
I've tried to look on that link but cannot see instructions for wiring in a new electronic regulator.
Hopefully there'll be instructions in the box
richardh
Postby Guesi » Tue Jan 28, 2020 3:44 pm
Which brand of regulator are you planning to buy ?
Guesi Motorradteile
MZ spare parts
Postby richardh » Wed Jan 29, 2020 7:29 am
either the WASSELL reg or the little blue box - sorry don't know the name
they both have D+ DF Batt and earth
I know that my 150/1 has the wire resistor in the generator near the brushes - but just like to know if the electronic regulator does not need the wire resistor please
just uses the 4 wires from the regulator to brushes / battery and Earth
thank you
richardh
Users browsing this forum: No registered users and 106 guests
