Barn find 1974 TS 250
Postby allkidd » Mon Dec 16, 2019 6:00 pm
Recently I purchased a 1974 TS 250. I don't know much about its history but it has sat for at least 10 years. Previous to purchasing this bike, I hadn't ever heard of MZ so this is all new to me. Also, this will be my first restoration.
I've always performed all the work on my modern two stroke dirt bikes, but I'm finding working on a vintage bike is a different game. I've always taken for granted the availability of parts, manuals, assistance, 6 volt, points etc.?? Currently, there is 6 inches of snow on the ground so I figure a restoration project is good therapy for not being able to ride my dirt bike!
It appears the bike is complete and in pretty good condition...other than sitting in a barn for at least 10 years. Everything including the chrome and paint appears that it will clean up nice.
I've debated where to start on the bike and how far to go. With a few new wires, I was able to establish that it has a spark. I'm tempted to clean the carb and see if I can get it started but wonder if I should check the engine out before running?
Would anybody recommend a good source for parts? At a minimum I will need all cables, brake pads, fork seals, wheel bearings, front blinker lens and probably many other items as I progress thru the project.
I haven't seen many of these for sale so I don't even have an idea of what is worth once running and in good condition?
Any help is sure appreciated and I'm hoping this is a good source of help as I progress thru my first restoration.
Beta Xtrainer 300 Dirt and Rocks
KTM 1190 Adventure
MZ TS 250 Project
Yamaha yds2 250 Project
allkidd
Re: Barn find 1974 TS 250
Postby DAVID THOMPSON » Mon Dec 16, 2019 6:19 pm
they imported a bunch of the 1974 models
and parts can be found
have fun it will be easier to find parts for it than most 1974 models
Dave :smt006
Postby Puffs » Tue Dec 17, 2019 5:24 am
Nice bike!
Spares: viewtopic.php?f=5&t=9257&p=47896&sid=dd7bca9749d861dca2e4e65aa9895542#p47896. Almost everything is available.
Manuals: see signature of member Blurredman elsewhere on this forum, or Miraculis.de (official manuals in German).
Value: is a local thing. Value in the US I don't know. A clean & well kept one in Germany has value.
Clean the carb. Beware: clutch may be stuck. Gearbox oil. Riding on salt-sprayed roads gives corrosion.
If stored in a humid environment for a long while, you may have corrosion on the internals (liner, rings, small/big end, main bearings). If you have compression, the rings are free & corrosion on the liner is no big issue. Corrosion on the bearings: there's nothing you can do there, if it's bad they'll fail at some stage (but that can take a while). Do not forget to premix oil into the fuel.
But of course it wouldn't hurt to take the head off & have a look inside. You will then need new gaskets though, but if you are going to restore the bike it will come to that.
Can you post some pics?
Postby allkidd » Tue Dec 17, 2019 12:56 pm
Hey Guys,
Thanks for the sources for parts. Now finding parts won't be such an issue. If only I could read languages other than English!
KTM 1190 Adventure
MZ TS 250 Project
allkidd
Users browsing this forum: No registered users and 44 guests
