I see. But knowing only length & diameter is insufficient to calculate the spring rate, for that you need more info:
- Spring rate formula.jpg (11.85 KiB) Viewed 1608 times
(There are spring rate calculators on the web.)
If you feel you need another spring rate for this bike, for whatever reason, the spring you desire might be difficult to find. Either have it custom made, or play with:
- preload (length of spacer 5),
- damping (if there is no adjustment: oil viscosity),
- changing the oil level (higher for a stronger progressive spring action),
- you could even consider additional air support (via a channel through caps 3).
