traderyoda wrote:Those Rickman "ankle buster" foot rests are strong but somewhat impracticable. Slippery too!
The MZ has a Rickman aluminum conical hub up front. Good unit, but not the best brake setup out there.
I won't change anything on the bike. I do need to ensure that no one removed any parts over the years though. I'm trying hard to find earlier pictures of the bike, including when it was offered on on eBay in December 2009 - hopefully someone on this Forum kept those pics.
It was built as an experimental machine for a fellow in California (Lynn Wineland) and tested in the desert to evaluate the capabilities of the motor. The exhaust is the ISDT version, but it wasn't initially shipped for England this way. I suspect the pipe Rickman installed was a poor match for the power band of the motor, so it was removed and the ISDT pipe installed; I'll leave it this way.
I suspect the electrics on this bike were never really sorted out properly. I see signs of burned out parts and the wiring harness was hanging loose. The case was left loose and a mouse ate all of the wiring on the dynamo. Perhaps the dynamo, designed for bike with lights, was never adjusted for a MX/desert racer with no lights. I'll first try to see if I can rebuild the dynamo and ensure the output is matched to the twin-coil ISDT setup. If not, I did find the VAPE setup and will go that way. I'm sure someone on this extensive site has set things up on a machine with no lights.
Users browsing this forum: No registered users and 35 guests
