Baghira rear light wiring problem
Postby gaz6963 » Sun Aug 25, 2019 3:34 am
Hi all, my first post, loving the forum.
My issue is the rear light.
With the original rear light attached and ignition on and light switch on, the rear light comes on but no brake light.
With an after market rear light fitted, light switch off, I have a brake light but no tail light. With the light switch turned on, I have neither a brake light or tail light.
Any suggestions please? I am not tech minded.
Thanks in advance
Gary
gaz6963
Re: Baghira rear light wiring problem
Postby DAVID THOMPSON » Sun Aug 25, 2019 8:12 pm
leave the tail lamps out of this test
find brake lamp switch use volt meter to see if you have power to one side of
switch or other test this with key off and on
then look at the wires at rear does one have power when break is applied
next most bike and autos loose dash lights if no power to tail lamps
this warns no fuse in the circuit
now take meter and see how lights are wired
Postby Sully5976 » Tue Aug 27, 2019 2:00 am
following this one
i have same issues too.
3 wires. connected no running light, ( to note all dash lights etc working fine)
brake light works when pressed,
when i switch arounnd wires etc the rearlight does come on but very dim, i have checked the light unit direct to battery and it is fine.
ihave played around so much that now the bike has now bloody spark either lol
Sully5976
Postby gaz6963 » Wed Aug 28, 2019 12:57 pm
Spoke to a motor electrician today who's inital thought is that there is a dodgy earth. I hope to get it seen too next week and update you.
gaz6963
Users browsing this forum: Bing [Bot] and 124 guests
