TS 150 battery won't hold charge
Postby Andybantam71 » Mon May 27, 2019 10:46 am
Hello all, I have a 77 TS150 that the battery is losing charge when running, I am only getting 5 volts at approx. 2000rpm(the battery was charged and checked out ok). The bike has a original style regulator(metal domed cover) so I am thinking it's either the regulator the coil or the commutator? any help or suggestions would be greatly appreciated. Many thanks, Andy.
Andybantam71
Re: TS 150 battery won't hold charge
Postby DAVID THOMPSON » Mon May 27, 2019 2:06 pm
charge battery and measure battery and check to see if it drops without being hooked up
to bike
Postby Andybantam71 » Tue May 28, 2019 3:38 am
Hi Dave, thanks for your reply. The battery holds a charge when not on the bike, I've got a output from the coil and the dynamo checks out ok. If I turn any lighting on even including the brake light it kills the engine. Regards Andy.
Andybantam71
Postby DAVID THOMPSON » Tue May 28, 2019 7:54 am
try a different battery or load test the current one some times battery will show 6 or 12 volts
but will not deliver any current flow
Postby Andybantam71 » Tue May 28, 2019 8:25 am
Hi, thanks again but the battery checks out ok. Regards Andy.
Andybantam71
Postby Puffs » Thu May 30, 2019 4:38 am
Postby Andybantam71 » Thu May 30, 2019 7:10 am
Hi, thanks for your reply. I've ordered a coil, regulator, condenser and carbon bushes so I'll see how I get on. Regards Andy.
Andybantam71
Postby Puffs » Fri May 31, 2019 4:49 am
