[Grand Designs] project - my ETZ 250
Re: [Grand Designs] project - my ETZ 250
Postby Blurredman » Thu Jan 17, 2019 7:02 am
If the gasket tore in a specific way, ie split longways type of break, rather than a straight up break like it was cut, then you can overlap the two pieces indeed with items that Puffs has mentioned.. Then apply to the crankcase.
Postby Puffs » Thu Jan 17, 2019 8:23 am
Postby dirtsurfer » Sat Jan 19, 2019 3:12 am
parrbd wrote:Those gaskets are easy to break. Best to lay the bike on its side when installing. Yes it has been hot. I was out on the ETZ today looking for the stingray swamp swimming hole in Penrose forest. Did not find it so had to ride back dusty and sweaty.
A bit cooler down your way though?
Stingray Swamp sounds interesting Bruce . I look forward to exploring the area with you.
parrbd wrote:I wonder if the gear lever off the DR (in the background) would fit?
Nope , the DR selector shaft is thinner
Blurredman wrote:.....
In terms of locking the crank.. I use rope down the plug hole. This stops the piston getting to TDC so it locks.
Brilliant ! That's what I love about forums like this. The bike was actually parked near my rope bucked when I read your post.
Now I have torqued down the clutch side and the Vape side, adjusted the clutch (for now! ) and fitted the tacho drive. Poured the drained oil back in.
Spent a few hours mucking around with wiring. Tomorrow I might go and buy some fuel and see if it starts.
MZochist
dirtsurfer
Postby dirtsurfer » Sat Jan 19, 2019 6:28 pm
and it does https://tinyurl.com/ybdv8wx2
It took 4 or 5 kicks to get it going :oops:
I know about the dubious value of the expansion chamber but I was ordering some parts and couldnt resist. I have the original exhaust but needs decoke, clean and finishing
MZochist
dirtsurfer
Postby Puffs » Sun Jan 20, 2019 4:56 am
Postby Andy_C » Sun Jan 20, 2019 10:53 am
Re expansion pipes.
The short one (which seems to be the only one you can get) will fit to the standard bracket - you may need to bend it a little but it will fit, at least it did on mine.
Being a short pipe you will find that it robs the engine of what little low down torque that these engines have, instead of starting to pull at around 3500 RPM it will move it up about 1000RPM, it also robs some of the mid range, however you will find that the motor revs much more easily and you can exceed the red line (6500RPM?) easily - not much point as you do not get any more power.
Basically with these short pipes you have to be revving the motor pretty hard to maintain a decent pace.
My "solution" was to weld a 10" (or therabouts) long cylindrical section in the middle of the pipe, and as far as I can feel it now works at least as good as, if not better than the standard pipe - I'll post up a pic of the pipe sometime if anyone wants to see it.
Just thought you might find my experience useful.
Andy_C
Postby Blurredman » Mon Jan 21, 2019 3:26 am
Just so you know, ETZ 251 and ETZ 250 have different length gear levers..
You'll obviously want the ETZ250 (?), which is the longer of the two.
Postby dirtsurfer » Mon Jan 21, 2019 4:50 am
Blurredman wrote:Just so you know, ETZ 251 and ETZ 250 have different length gear levers..
:oops:
I've ordered 250/251/301!?. I guess I'll find out if it fits when it arrives.
Andy_C wrote:Re expansion pipes.
Yes a picture please
MZochist
dirtsurfer
Postby Puffs » Mon Jan 21, 2019 6:17 am
The problem fitting the bracket is that standard both connections are to the rear of the shock, while here the connection to the pipe is forward of the shock.
Dirtsurfer, do you know which clearance your new RAM piston has?
Postby Blurredman » Mon Jan 21, 2019 6:36 am
:oops:
To be fair the ETZ 250 lever is longer, but also barely misses the tacho drive.. I think they realised this later on when they shortened it. The shorter one on the 251 can be easier to use if you have big feet, as this prevents the tacho housing interfereing with your foot trying to change gear...
Either way.. I am not even sure which I prefer.. The longer one for the leverage, or the shorter one for less interference ......
Postby dirtsurfer » Sat Jan 26, 2019 11:48 pm
Puffs wrote:The problem fitting the bracket is that standard both connections are to the rear of the shock, while here the connection to the pipe is forward of the shock.
I think the bloke that rebored the cylinder told me .06
MZochist
dirtsurfer
Postby dirtsurfer » Sun Jan 27, 2019 12:07 am
dirtsurfer wrote:and it does https://tinyurl.com/ybdv8wx2
A couple more setbacks
For reasons too complicated and not really interesting enough to post here; I was unable to access my bike for about 24 hours after I created that video. In that time the entire litre of premix drained from the leaking fuel tap. When I could access the bike again, I tried to restore the fuel tap with some miscellaneous O rings that I had laying around. This made it leak worse. . I hoped one of my BMW taps might work but they're bigger.
I had a look at my original muffler, tapping the input end on the ground , about 300 grams of rusted material fell out. When I shake it I can hear more, inside sifting through what is left of the baffles. At the output end I can feel decaying material with my finger
MZochist
dirtsurfer
Postby Puffs » Sun Jan 27, 2019 6:44 am
Postby Andy_C » Sun Jan 27, 2019 10:37 am
Dirtsurfer - you wanted a pic of the modified spanny on my ETZ.
Here it is attatched to the ETZ.
As I say it works just fine in my opinion - possibly even better than standard.
I have been told it looks awful - IMHO looks no worse than the standard "drainpipe" but each to his own.
Andy_C
Postby Puffs » Mon Jan 28, 2019 2:48 am
