arny wrote:When discussing electronic ignitions I guess it would also be interesting to mention which ones do control igniton advance...
So far the only one I am aware of that does automatic advance is Powerdynamo/VAPE ignition. Most other aftermarket ones including Gotronic I mentioned, don't vary ignition advance but are simple "transistorised ignitions" i.e. serve only as maintenance free points replacement.
Are there other aftermarket ignitions that vary advance timing automatically?
Does any of the stock MZ electronic ignitions vary advance timing automatically?
Puffs wrote:Arny, I don't know the answer to your question insofar as pertaining to electronic ignitions for the older 2T MZ engines.
A question I have is: are you sure that Powerdynamo/Vape advance the ignition timing? Would you have an advance curve?
