Puffs wrote:This all looks quite dreadful, and all your bearings will have corrosion on them. Even if they rotate freely & with little apparent play, they're likely to run noisy and fail soon when you start running the bike. My advise is to replace all bearings (main, conrod, but probably also gearbox, wheels, steering head) & seals. A conrod set is cheap & doubtlessly they can press & balance in Oz. Otherwise buy a complete crankshaft. You may also need a rebore & new piston (including pin - small end).
Andy_C wrote:When I took the clutch off my ETZ 250 it took a lot of persuading !
I used the proper puller and what I did was to tighten the scew as much as possible, then apply some heat, bashed it with a mallet and I woudl find that the bolt would turn perhaps a quarter of a turn more.
I just kept on repeating that time after time, and eventually it came off.
Problem that I think you may have is that the clutch is rusted onto the taper, which may make it virtually impossible to remove - looking at the state of that engine perhaps a replacement motor might be in order, it's just finding one, they do pop up on E-Bay fro time to time.
Good luck.
Andy_C wrote:Edit - there is one on E-Bay at the moment - https://www.ebay.co.uk/itm/mz-etz-250-e ... SwOFBag1E6
