MZ Skorp - tank removal
Postby WaiNYC » Sat Nov 04, 2017 3:07 pm
It's been awhile since I last used this site. Hope all is well, and your MZs are running well and strong.
Quick question: Is it necessary to take out the petcock prior to removing the gas tank?
I remember when I restored my bike http://www.mzriders.com/viewtopic.php?f=3&t=8119 back to life more than two years ago, I had to first take out the petcock, and that was messy and a pain to do because of the need to empty the tank of gas.
Any tips of how to do this more efficiently? Thanks for the help.
Wai
WaiNYC
Re: MZ Skorp - tank removal
Postby Windmill » Sat Nov 04, 2017 3:39 pm
Hi Wai, I've a Skorp Sport and have never removed the petrol tap to get the tank off. I've taken it off a number of times and as I recall, its a bit fiddly clearing the wiring loom but nothing more than that. Not sure whether its different between models ie sport/traveller etc though. Sorry, cant give any real tips here but mine certainly comes off without. Cheers, David.
Windmill
Postby WaiNYC » Sat Nov 04, 2017 3:42 pm
Windmill wrote:Hi Wai, I've a Skorp Sport and have never removed the petrol tap to get the tank off. I've taken it off a number of times and as I recall, its a bit fiddly clearing the wiring loom but nothing more than that. Not sure whether its different between models ie sport/traveller etc though. Sorry, cant give any real tips here but mine certainly comes off without. Cheers, David.
Thanks for the reply Dave. Mine is a 1996 Sport. Yours?
WaiNYC
Postby Windmill » Sat Nov 04, 2017 3:45 pm
a 95, brings a smile to my face every time I ride it......
Windmill
Postby WaiNYC » Sat Nov 04, 2017 3:52 pm
Windmill wrote:a 95, brings a smile to my face every time I ride it......
Actually I remember wrong. Mine is also a 1995. Even though the bike has spent many years in storage, I'm the only owner from day one.
I wonder how many first year Skorp Sports are still out there...
A few bubbles started to show up on the front fairing, underneath that thick coat of yellow paint. Is yours the same?
WaiNYC
Postby DAVID THOMPSON » Sat Nov 04, 2017 3:55 pm
TAKE IT OUTSIDE THIS IS A MESS TO DO
a straight piece of brake line and a hose and siphon the extra gas out of the tank
it does not all drain even on reserve
then remove petcock from tank
unbolt from frame but not at the first set of bolts too much danger of tank damage
many 4 letter words follow
Postby Windmill » Sat Nov 04, 2017 4:02 pm
yes wai, bubbles on the tank (usual fuel/fibreglass woes) but someone had repainted mine so its no longer yellow.. its now black. Only had mine since I joined here so 2012? I think. no intention of ever selling at this stage, its one of those that just always works. :D
Hi David, hope you are well long time no speak.
Windmill
Postby DarkLeftArm » Sat Sep 28, 2024 9:48 pm
DAVID THOMPSON wrote:TAKE IT OUTSIDE THIS IS A MESS TO DO
"unbolt from frame but not at the first set of bolts too much danger of tank damage"
Can you please elaborate on this sentence?
Sorry to revive such an old post, but I'm getting ready to access the carbs on my 02 Skorpion, and have been puzzling over fuel tank removal.
I gently tried unscrewing the two 10mm headed horizontal bolts under the back of the tank, but they just spun. Now I'm considering the 4 smaller allen headed screws securing the rear tank support. Any suggestions?
Thanks!
DarkLeftArm
Users browsing this forum: Uncle Nick and 29 guests
