DAVID THOMPSON wrote:hay andy may i pull your LEG sadly lackiing in power. describes most everything about any bike less than 500cc
made before 1980
Blurredman wrote:My rear ones have always been pretty good even with crappy shoes..
How about you adjust the leverage at the brake end so that a lot less travel is required to bite?
Or perhaps even changing the shoes I guess..
AlanJ wrote:Hi Andy,
I don't want to seem to be telling you how to suck eggs, but I thought this post might give an opportunity to mention about braking and weight transference and the fact that whatever one does to slow the motorcycle ie. close the power or use either of the brakes then weight transference occurs and the back wheel will have less friction on the road, it will skid sideways, not good obviously, so, if you get your back brake to lock on it might not be to your advantage, again , it's obviously got to work and stop the rear wheel from rotating, finally. Anyway I have found a great site about braking and thought to add it to this post. Tips for braking on a motorcycle - Lazy Motorbike http://www.lazymotorbike.eu/tips/braking. it's a Dutch site. I'm sure you know about all this but some people don't, so there you go.
Take care All Alan.
Users browsing this forum: Bing [Bot] and 49 guests
