cutting out
cutting out
Postby andyj50 » Tue Dec 27, 2016 3:11 pm
hi, was hoping someone can help me out
got a ts150 when I switch the lights on the bike cuts out, so I upgraded to a new solid state rectifier today but the problem is still there, it will run on dipped beam but as soon as I switch to main the bike cuts out, any ideas thanks
andyj50
Re: cutting out
Postby DAVID THOMPSON » Tue Dec 27, 2016 5:25 pm
sounds like a short in the high beam circuit or the switch
look for a pinched wire some where
inspect inside the head lamp shell
and the bulb may have shorted high beam to ground inside the glass bulb or has gone open
include the hi/low switch in your checks
and watch for small parts they may never be found
go to a second hand store and buy a bed sheet spread it out and work on bike on it with a piece of cardboard for an oil drip
little tiny things are easy to find on a sheet
Re: cutting out
Postby andyj50 » Wed Dec 28, 2016 10:42 am
hi, thanks for the reply got a spare bulb to try and someone mentioned trying the high low switch on the bars as well will have another go at the weekend and see if I can find any dodgy wires while am at it
andyj50
Re: cutting out
Postby DAVID THOMPSON » Wed Dec 28, 2016 2:06 pm
these bikes are getting older and some the quility of the original wires was not to good
even in my 2002 rt125 the wires to the turn signal wires were routed wrong and way to short
had to drill a hole in the plastic parts and route the wires in a more direct route
the wires were so tight you could play a tune on them ..
Re: cutting out
Postby andyj50 » Sun Feb 05, 2017 12:01 pm
bit of a late reply, but problem solved, was the ht lead into the coil,wasnt seated inside correctly
andyj50
Users browsing this forum: No registered users and 235 guests
