Mastiff choke actuation method
Postby breakwellmz » Wed Aug 17, 2016 2:08 pm
Hi
Is there any reason i can`t replace the current rotary `indexed`choke lever for a `traditional`friction horizontal one? The standard one requires the drilling of a location hole in the `bars to prevent rotation.
:idea: or maybe a bicycle gear thumbthifter :idea:
Re: Mastiff choke actuation method
Postby Rustyhub » Sat Aug 20, 2016 10:46 am
I think I've seen a yahama sourced, carb mounted plunger type solution...maybe from an xt600??
Rustyhub
Postby breakwellmz » Tue Aug 23, 2016 1:52 am
Hi.
Yes i`ve seen those, expensive though.
I freed the cable at the handlebar end yesterday and was surprised how light the pull needed to actuate the `choke`was.As a result i removed the pip that engages in the hole in the bars to stop the thing rotating, allowing me to fit a pair of bars without having to drill a hole in them.
I may well fit a bicycle friction gear thumbshifter at some point though.
Cheers
Users browsing this forum: Bing [Bot] and 49 guests
