Top speed no wind MZ Rt125
Postby jojo » Mon Jun 27, 2016 9:28 am
Hi guys i just wanted to check what is the your top speed on the rt or sm 125 as mine struggles past 60mph. everything is stock and i have a windshield installed but didnt help much.
PS i weight 65kg
Mz RT 125 2004
jojo
Re: Top speed no wind MZ Rt125
Postby DAVID THOMPSON » Mon Jun 27, 2016 4:48 pm
with about 8000 miles on it mine would do almost 70
i changed the gearing it will do 68 mph flat out with a 52 tooth on the rear 49 was stock
its at 23,000 it does 55 ok but its weak in the area from 55 and up and 60 and up is hard on it
putting the 49 back on is a joke it loads it down and and its hard to do 55
Dave
220 lbs and 5f 11in some times called "ton of fun"
Postby stephendacosta » Mon Jun 27, 2016 10:24 pm
I have a lot of MZ 125's. The most often successful corrections to lack of power are jetting (using a 105 main jet) and retiming the cams to be spot on. --Steve
Stephen DaCosta
stephendacosta
Postby jojo » Wed Jun 29, 2016 2:20 pm
@Wow that's pretty poor Dave. With 15bhp I was expecting something more spectacular. I could barely keep up with a cbf125 the other day. Annoying as it is 4bhp weaker than my Rt125.
@Steven is rejecting really going to make a difference? Current seeing should be the best right?
Mz RT 125 2004
jojo
Postby DAVID THOMPSON » Wed Jun 29, 2016 9:28 pm
factory setting is to keep the EPA HAPPY and not get over 15hp
some location did and still have HP limits for a 125cc 15hp power limit for beginners
if its less than 350cc and 30 hp
its just a big MOPED
Dave
Postby vicar » Thu Jun 30, 2016 4:14 am
Dave your 350/30 hp comment is wrong a 250 Mz is not a moped !
vicar
Postby DAVID THOMPSON » Thu Jun 30, 2016 7:40 am
It must have more hp than any 2 cycle bike i have ever owned..
But you need to understand the hill country i live in there
steep and your always climbing one any time you
Leave the house
Dave
Postby jojo » Sat Jul 02, 2016 3:59 pm
Update.
Thanks for the replies guys. So after considering the option of a bigger jet I decided to first check my air filter.
I cut it out and changed to a a foam type from Ramair (only cost £3 for a large sheet of 20x30cm)
Takes a little bit of patience and sharp cutters but I managed to do a decent job.
Performance: still same top speed of around 62mph but I get there so much quicker :-D
Also the gears seem to pull stronger too. The bike is overall slightly qieter which is a little strange
Im more thinking of reducing the rear sprocket to 47teeth to gain top speed. Any other suggestions?
Mz RT 125 2004
jojo
Postby DAVID THOMPSON » Sat Jul 02, 2016 10:03 pm
if it has over 10.000 miles i will be surprised if you gain any speed
when i want to go fast i get out the Saxon Tour rotax powered 500
Postby jojo » Sun Jul 03, 2016 7:28 am
Hi Dave,
My bike is 25000 on the clock do maybe it is as you said :cry:
I live in London so I don't really need blistering speed. I just want to be able to keep up on 70 mph A roads.
I was struggling between this amazing little bike and a cb400 Honda, suffice to say this a much better looking and practical bike. It also so easy to ride pity I cant have it all :(
Mz RT 125 2004
jojo
Postby DAVID THOMPSON » Sun Jul 03, 2016 9:52 am
where i live most posted speeds are 45 mph a few ai 55 , 1 at 65 and 1 at 70
so mine is rt125 stock front and 52 tooth sm sprocket on rear
requires an adaptor made from the center of the old 49 tooth sprocket
with longer bolts the 49 had an offset so use center of 49 as a spacer to keep chain aligned
it is almost perfect for what i do
over here most 125 cc
street bikes are found dead at 8 to 10 thousand miles as there abandoned it the barn
as the riders feed the need for speed with something BIGGER
cb400 is badly abused over here most are toasted out at 30 thousand as the owners flog the hell out of them
Return to 125 cc
Users browsing this forum: Google [Bot] and 11 guests
