660 Scorpion cam chain tension
Postby Petrolhead » Sat Jan 16, 2016 11:30 am
I can't find a reference on the net to doing the cam tension, is it an automatic one (read somewhere its spring loaded) or is there a sequence to tension it? :?
I'm working my way through servicing it, need to change oil, coolant and check valve clearances too but these are covered in the MZ660 and SZR660 manuals I down loaded from the net.
Petrolhead
Re: 660 Scorpion cam chain tension
Postby edfmaniac » Sun Jan 17, 2016 9:34 am
Cam chain tensioner is spring loaded. You shouldn't have to check how far it has extended until the chain is nearing the end of it's service life. What that is, I couldn't tell you.
Postby Petrolhead » Sun Jan 17, 2016 10:02 am
Is it an automatic self adjusting one? The Skorpy has only done 2430km/1400 miles from new.
Petrolhead
Postby edfmaniac » Sun Jan 17, 2016 8:08 pm
Yes. It's spring loaded with a ratcheting device that doesn't allow the chain to loosen once the spring pushes on it hard enough to engage the next tooth on the tensioner. If you are concerned, you can remove the unit and check to see how far it has been pushed out. Remove the big bolt first, then the smaller ones, or the spring will just push it out fully when removed. Retract it all the way before reinstalling.
Postby Petrolhead » Mon Jan 18, 2016 8:20 am
Thanks very much for that, its put my mind at rest. I don't think i'll take it out to check as the engine is very quiet just now with the low mileage I mentioned. :D
Petrolhead
Postby dandywarhol » Mon Jan 18, 2016 12:07 pm
edfmaniac wrote:Yes. It's spring loaded with a ratcheting device that doesn't allow the chain to loosen once the spring pushes on it hard enough to engage the next tooth on the tensioner. If you are concerned, you can remove the unit and check to see how far it has been pushed out. Remove the big bolt first, then the smaller ones, or the spring will just push it out fully when removed. Retract it all the way before reinstalling.
ONLY take it out when the crank and camshaft are at the timing position - otherwise there is a very high possibility of the chain jumping :?
Whale oil beef hooked
dandywarhol
Postby DAVID THOMPSON » Mon Jan 18, 2016 7:27 pm
i keep the chain under tension with a bungy cord and a lever
nothing like getting one out of time
