Skorpion Sport pipe from inlet manifold
Postby timston » Tue Jul 14, 2015 3:48 pm
can anyone tell me what the pipe that runs from the rubber inlet manifold of the primary carb to the fuel pump does?
Cheers
Tim
timston
Re: Skorpion Sport pipe from inlet manifold
Postby DAVID THOMPSON » Tue Jul 14, 2015 8:35 pm
I think its a vacuum operated fuel pump take it off
it may have been left on to get a faster slide past epa inspectors
its not needed on mz and just something to give problems on the road
it was for some models of yamaha and this tank will gravity flow
OK if lines are clear and not kinked
Dave
do save it and a drawing so if needed later at a nit picking safety inspection
says you have to have it.. even though it does nothing helpful
Postby timston » Thu Jul 16, 2015 2:26 pm
thanks Dave
So I can bypass the pump and just gravity feed the carb directly from the tank?
timston
Postby DAVID THOMPSON » Thu Jul 16, 2015 3:05 pm
make sure tank fuel tap and inside filter are open and tank vent is open
filter behind float needle in carb
put a big fuel filter on it
do not remove bolts in tank that hold metal bracket on they turn in the plastic
take the rear bracket with the tank it is not easy ..but best way
tank swells over time and is a beast to get off and one
and have fun
its not to heavy but its not lite either
watch getting off balance at stops if you are on tip toe ...once it starts to go it gets heavy real QUICK
Postby timston » Fri Jul 17, 2015 1:10 pm
thanks Dave
anyone else out there running without the pump? any problems to look out for etc
Cheers
Tim
timston
Postby droy » Fri Jul 17, 2015 8:38 pm
20 years and 75,000 miles and no issues
Likely 75percent of the scorpions are running that way
Doug in nj
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
