2002 125sx voltage regulator/ rectifier
Postby bharp1653 » Mon Jul 06, 2015 4:33 pm
Heres one for yall... hope somebody can help. The voltage regulator went out on my 125sx and I cannot find one anywhere short of trans-atlantic shipping. I dont mind cutting and splicing but I cant find a substitute. Any help would be appreciated. Any compatable parts list someone may have put together would be a godsend as well. Thank yall for your time. Love the bike, just need to keep her runnin.
2002 MZ 125 SX
"When in doubt, pull the trigger."
bharp1653
Re: 2002 125sx voltage regulator/ rectifier
Postby DAVID THOMPSON » Mon Jul 06, 2015 6:09 pm
http://www.electrosport.com/regulatorre ... phase.html
http://www.electrexworld.co.uk/acatalog/RR60.html
electrosport i think is in usa
may have to change the plug and find a sense wire its a point that goes on with the key
and supplies the v/r with a 12volt signal
mine blew firs day from a bad battery
rr60
Postby bharp1653 » Mon Jul 06, 2015 6:22 pm
Thank you sir. How about brake switches? Both of them are out. Im guessing those are kind of universal.
2002 MZ 125 SX
bharp1653
Postby DAVID THOMPSON » Mon Jul 06, 2015 6:48 pm
front is Aprilia or bmw r80 abot 82 83 r65 bmw maybe the 72 to about 75 HD AERMACCHI ss250 ss350
FOUND SWITCH AT BMW SHOP
BMW NUMBER= 61 31 1 244 070
front brake light switch
FITS BUNCH OF STUFF bmw apperlia ktm
Hydraulic rear brake light switch for Skorpion Tour (maybe others) is Aprillia #81244679. Thread is 10x1 mm.
probably same for other mz/muz
Postby bharp1653 » Mon Jul 06, 2015 7:53 pm
Thanks! Ive been catchin hell trying to get this bike right. Any advice on whether to leave it stock or change a few things?
2002 MZ 125 SX
bharp1653
Postby DAVID THOMPSON » Mon Jul 06, 2015 8:23 pm
leave it stock trying to make it go faster just makes it use more gas
and use this gas if you can get it
http://pure-gas.org/
here we call it mower gas or boat gas
Postby bharp1653 » Mon Jul 06, 2015 8:45 pm
I usually use a little octane booster and a bit of seafoam.I get real gas about 3/4 of the time, there is a station close. Thanks again for the help, ill be sure to come here first when somthing else comes up!
2002 MZ 125 SX
bharp1653
Postby bharp1653 » Wed Jul 08, 2015 7:05 pm
One last thing this go around. Would anyone know what oil filter to use for this bike? Im doing an oil change to royal purple and need to find a compatible replacement.
2002 MZ 125 SX
bharp1653
Postby DAVID THOMPSON » Wed Jul 08, 2015 8:06 pm
read the label on royal purple do not get something to slick in there and ware out the clutch
k and n 151 hiflo brand hf151 same as BMW f650 but BMW filter is $$$
i have been using Shell ROTELLA T 20w50 and have 21,000 on mine
Postby stephendacosta » Wed Jul 08, 2015 9:19 pm
I have a stock voltage regulator/rectifier. Also 5 stock rear brake switches. If you want them, let me know and I will look up the invoice for a price. Located in Ohio.
PM me if you are interested.--Steve
Last edited by stephendacosta on Sat Jul 11, 2015 7:35 am, edited 1 time in total.
Stephen DaCosta
stephendacosta
Postby bharp1653 » Fri Jul 10, 2015 7:29 am
Yessir, im interested in the voltage reg. How much you askin?
2002 MZ 125 SX
bharp1653
Return to 125 cc
Users browsing this forum: No registered users and 205 guests
