Baghira Carb Drain O-Ring / Teikei Parts Fiche?
Postby Dirt » Tue Apr 07, 2015 4:31 pm
Hi Folks,
Over the winter, I got overly ambitious and drained the 4NN(?) Teikei carb on my Baghira using the screw on the bottom of the bowl.
I fully removed the screw to clean it and now, upon reassembly, the carb drain leaks. Lovely.... I don't have a parts fiche for the carb and and I'm guessing there was an O-ring that did not survive the journey. Doh!
Anybody have a parts fiche for this carb and/or a part number for this O-ring? Any good source to order this (ideally in the U.S.)?
Thanks!!!
Dirt
Re: Baghira Carb Drain O-Ring / Teikei Parts Fiche?
Postby den » Wed Apr 08, 2015 3:47 am
just buy another drain screw , it will come with an oring ..
den
Postby Dirt » Wed Apr 08, 2015 8:49 am
Good idea.
This is a 4NN Teikei carb, right? Got a good source for Teikei parts?
Dirt
Postby den » Wed Apr 08, 2015 3:02 pm
ok , cheers for that ,
right .last word ,
the drain screw does not have an o ring ,
den
Postby breakwellmz » Wed Apr 08, 2015 4:24 pm
den wrote:just buy another drain screw , it will come with an oring ..
Postby Dirt » Thu Apr 16, 2015 3:38 pm
Hmmm... if the drain screw doesn't have an o-ring, any idea why it's leaking or how to stop it?
It was fine before I took the damn thing out, now it won't stop leaking and I'm pretty sure I'm seating it --- but maybe there's something jammed in there preventing it from seating?
Dirt
Postby duncmac » Fri Apr 17, 2015 1:33 pm
Could be some crud or grit stopping it sealing
If you dont want to take off the carbs, try draining some petrol through it with the drain screw out.
Otherwise a bodge could be to use some plumbers ptfe tape, the white thin stuff they use for thread sealing, but a bit round the end maybe.
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Postby Dirt » Sun Apr 19, 2015 7:18 pm
Taking off the carbs is a PITA due to tight clearance-- have done it twice already and would definitely prefer not. If there is no O-ring, I'll try just opening it up to flush it and then reinserting the screw. If that doesn't work, will try PTFE tape (for Propane and natural gas might be a little more resistant).
Without a microfiche, I wasn't sure if I lost an o-ring or not. If there is one, will try flushing/blowing the hole out.
Thanks for the help!
Dirt
Postby Dirt » Mon Apr 20, 2015 8:40 am
oops.... meant "If there isn't one [an o-ring], will try flushing/blowing the hole out"
Dirt
Users browsing this forum: No registered users and 227 guests
